Results 1 to 10 of 10
Thread: Time for a new liner??
    Jul 2012
    Chicago, IL
    356
    Hey All,
    Just after closing my pool (in October) I noticed that the water level seemed to fall a couple of inches. I assumed the source of the leak was a spot that had previously been patched (it was patched when we bought the house, and then I re-patched it early last season as I saw the patch had pulled away). I reached down into the very cold water to try and pull the patch off and it ended up tearing the liner, maybe an 8 x 3 inch section, can't recall exactly. I patched this new large tear as best I could but the water was frigid so I am certain it is imperfect. Everything is frozen solid now so no leaking. It wouldn't seem that this would be too big to patch, but wondering if the way the liner tore is suggestive that it is time to simply get a new one? Just guessing, but the liner is likely 7-9 years old.
    If it is time for a new liner, is there anything else I should think about doing, or simply pull out the old, and drop in the new? (I've never done anything like this so I would likely pay a pro to do it.)
    Thanks!
    Paul
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Casey's Avatar
    SW PA
    10,444
    Re: Time for a new liner??
    Paul, I would replace the liner if it's that old. It's really not that difficult either. YouTube liner replacements in above ground pools to get an idea and get a few friends together and save that money for pizza n beer.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would also not skimp on the thickness of the liner. Get the thickest in mill's you can.
    I agree with Casey on the pizza n beer. Second thought, skip the pizza. Takes up too much room that could be used for beer !! Lol.
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Exactly.
    Quote Originally Posted by pwrstrk View Post
    Divin Dave,
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Third thought, skip the beer. Takes up too much room that could be used for margaritas !! Lol.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by JayBauman View Post
    That's better yet !!
    Jeff
    Casey's Avatar
    SW PA
    10,444
    Ok... when we meeting at Paul's to get drunk? I mean put his liner in....
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by Casey View Post
    When it warms up !!
    Jeff
    Jul 2012
    Chicago, IL
    356
    Well, I can see we have some pent up Northerner's in here! Thanks for the input. Was really hoping to add a heater this year so trying to be budget conscious, I may yet see if I can patch it up and survive one more season. I'll watch some videos on liner install as well, the current one has a number of large wrinkles at the bottom so wasn't sure if it took some amount of care/skill/experience to ensure that those wrinkles do not happen again.
    What am I going to find underneath the liner? Sand?
    Casey's Avatar
    SW PA
    10,444
    More than likely you'll find sand that has algae n may have moldy looking spots. It's completely normal. You can treat it with bleach mixture sprayed on it.
