Thread: Using the pump to drain water
    Aug 2014
    Palm Bay, FL
    17
    The picture you see shows my filter housing, which contains a cartridge filter.
    Last fall, a "pool school" guy came out to give some basic information.
    If I recall correctly, one of the things he said was not to use the drain plug shown in the picture to drain water from the pool (the one that appears to me to have been put there for just that purpose). I'm not sure of his reason: I vaguely think it was because it wasn't supposed to be good for something (too much stress or pressure on the housing or pump perhaps? I don't know).
    We get a lot of rain, and any other method I can think of for draining the pool after it overfills after a good downpour would be a lot more hassle than unscrewing that drain plug and turning on the pump.
    1) Was the guy right or wrong?
    2) If I do unscrew this plug to drain the pool, should I leave the return valve from the filter housing to the pool open or closed while draining?
    Thanks!
    5k gal, IG vinyl, Sta-Rite P2R (or P2RA?) series pump, 100 sq ft cartage filter, install date 1996
    Re: Using the pump to drain water
    1) Both, kind of. Draining water through the drain plug is fine. The problem is that if you remove and replace the drain plug too many times it can break, at which point you end up having to replace the entire filter. That isn't likely to happen, but fairly expensive if it does. If you did this once, I wouldn't worry about it at all. But if you do it every week I would expect you to eventually have a problem. What some people do is attach a pipe with a valve to the drain plug socket, so you can just open the valve when you want to drain.
    2) Leave the return valve open. It will drain a little slower, but will avoid some possible problems.
    Jul 2014
    Winter Springs, Florida
    113
    I have a similar setup and I plumbed a valve there similar to what bobodaclown did here:
    http://www.troublefreepool.com/threa...lumbing-SOLVED
    ~16000 gallon in-ground gunite. Pentair 160316 cartridge filter. Testing with TF100. Baracuda G3 cleaner.
    Aug 2014
    Palm Bay, FL
    17
    Thanks for the great info!
