Results 1 to 14 of 14
Thread: salt system for aluminum
    May 2014
    amsterdam ohio
    26
    Should I use a salt system for an aluminum above ground pool?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Sure you could use a SWG on that pool. Are there any steel or resin parts ? I would just make sure it wouldn't void any warranty on it.
    Welcome to TFP !
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: salt system for aluminum
    Welcome to the forum. Go for it if ya' like!
    Mar 2007
    San Rafael, CA USA
    12,082
    If the aluminum is exposed to water then you should connect the aluminum to a zinc (or magnesium) anode buried in moist soil to help prevent metal corrosion from the higher salt level. Aluminum is not as corrosion resistant as the stainless steel typically used in pools.
    Apr 2010
    East Texas
    9,552
    I was never aware the steel pool walls were, or at least could be, of the "stainless" type?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've seen them where the panel for the skimmer and return fitting is stainless steel.
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by woodyp View Post
    I don't know either, but I think cg meant SS components in general like hardware, handrails, etc.
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, for stainless steel I meant general hardware such as handrails and light rings.
    Apr 2010
    East Texas
    9,552
    I was gonna say............that was gonna be one expensive pool wall!
    May 2014
    amsterdam ohio
    26
    Thanks for all the advice. I will have to check about the steel. The skimmer bolts are probably stainless would that be a problem?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by daveva View Post
    I don't see a problem. All the hardware that comes with the pool should be SS.
    Jeff
    Jun 2008
    Port Neches, Tx.
    144
    What brand pool are you looking at? Ours recently had a big limb fall on it and needs to be replaced. I found one that is built out of extruded aluminum panels. I have a SWG from our current pool and would probably continue using it. The one I read about has all stainless hardware which I think is important. Our pool came without stainless screws in alot of places and by the time I noticed it most of the screws could not be removed so they could be replaced. If I had to change the liner it would have been alot of trouble getting the top rail off. My concern with the aluminum pool would be that the top rails might get extreamly hot in the Texas sun.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    1 1/2 hp pump, sand filter
    May 2014
    amsterdam ohio
    26
    I bought 15' x 30' Oval 54" Bermuda. Thanks for the help everyone
    Mar 2015
    Cape Fear NC
    4
    Did you buy from Family Pool Fun? I am looking at their site and I like the pricing, but a little hesitant to order....
