Thread: Jandy RS485 protocol for Chemlink
    Apr 2014
    United States
    1
    I've been running a $10 RS485 adapter to monitor my pool equipment and extract some extra data from it (pump power/rpm, SWG performance,...).
    Now I'd like to automate the measurement of Ph and ORP using some Atlas Scientific probes.
    I would like to do this by faking the protocol of a Jandy Chemlink system, so the data shows up on the RS485 bus.
    Has anyone looked at this protocol? I can decode it from a sniffer, but I don't have the Chemlink device installed. I tried reverse engineering the Aqualink simulator communications, but without result so far.
    I have a full set of scripts and tools to look at it if anyone has an RS485 adapter and a Chemlink C1900 (or similar) device.
    16000 gallon gunite pool, Intelliflo VF pump (3HP), Aquarite 25k Gallon SWG (rev 1.59), Aqualink RS-8 combo, iAqualink wifi control panel (rev R)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Jandy RS485 protocol for Chemlink
    Welcome to the Forum,
    A tough one as I mentioned in PM, but hopefully you can find the answer to this one. Wish I could help more.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Divin Dave,
    May 2015
    Jenison
    2
    Hello pvancorenland,
    I think its great that you got the RS485 adapter to monitor your pool equipment. Have you posted source code of your scripts, diagrams of wiring, etc like on GitHub or anything (like opensourcing it)?
    Is it possible I can get a copy of what you did? I'm planning a pool monitoring and automation system that I'd like to build from Arduino and Raspberry Pi. Anything you can do would be appreciated!
    John
    Also I have to ask, is the SWG you are monitoring an Aqua-Rite?
