Thread: Pentair Easytouch/Actuator Issue
    Feb 2015
    Surprise, Az
    6
    My vale actuators have both stopped working within a month of each other. I was curious being a new pool owner, if i had to only use the pentair brand, or would others work as well.
    Thanks in advance.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pentair Easytouch/Actuator Issue
    I'm not sure, but hopefully someone will answer you better that I can. It seems odd for them to go out so soon. Welcome to TFP!
    Essential Links:
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    You can use any brand you want. They are all 24V and the connectors are the same.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    I think (although Pentair wont admit) there is a problem with the actuators. I have been warranting about 15-20 percent of all new actuators for the past couple of years. However, the problem that i have seen is not that the actuators are quitting, but rather, they are inconsistent in their rotation. IOW, Sometimes they will rotate fully like they should, and other times they will stop short from where they should be stopping. Then at the next rotation, they will rotate properly. This will lead to either the spa draining when the customer is trying to use it, or it will continue to over flow just a little bit, increasing heat times, or they work fine. I cant always get the problem to reproduce, which is making it difficult to diagnose. But since the problem is limited to new installs, i have been warranting them with just the symptom mentioned. The main reason that i think Pentair knows of this problem with them is the fact that they are warrantying these with little to no question.
    Factory Warranty Station for:
    Mar 2011
    441
    I used to have to replace 1-2 actuators a year now its 15-20. I wish pentair left well enough alone.
    20X40 30,000 gallon gunite pool
    Feb 2015
    Surprise, Az
    6
    Quote Originally Posted by Pool Clown View Post
    I think (although Pentair wont admit) there is a problem with the actuators. I have been warranting about 15-20 recent of all new actuators for the past couple of years. However, the problem that i have seen is not that the actuators are quitting, but rather, they are inconsistent in their rotation. IOW, Sometimes they will rotate fully like they should, and other times they will stop short from where they should be stopping. Then at the next rotation, they will rotate properly. This will lead to either the spa draining when the customer is trying to use it, or it will continue to over flow just a little bit, increasing heat times, or they work fine. I cant always get the problem to reproduce, which is making it difficult to diagnose. But since the problem is limited to new installs, i have been warranting them with just the symptom mentioned. The main reason that i think Pentair knows of this problem with them is the fact that they are warrantying these with little to no question.
    That is my problem exactly. Some times they work, sometimes they dont, and other times they go half way. My pool i sunder two years old so that makes sense then.
