Thread: Anyone used an Ezi-Action Drum Pump?
    Feb 2015
    Auckland/New Zealand
    18
    Has anyone used an Ezi-Action drum pump for getting liquid chlorine out of a 5 gallon (in my case 20 litre) drum?
    An overview of it can be found at http://www.nzpump.com/Blog_pumping_chlorine. Also http://www.nzpump.com/eziaction_drum_pumps
    You can also get a container that attaches to the nozzle for measuring the amount pumped out. http://www.nzpump.com/eziaction_safety_measures
    Sold in the US as well as New Zealand by the looks.
    Vinyl above ground pool. 27,000 litres (7,100 gallons). Single skimmer box. 40mm (1.5") piping.
    Filtermaster FX 1.0hp single speed pump (2,850rpm). 40mm top mount multi-port valve.
    Filtermaster F18 (450mm diameter) fibreglass wound sand filter using glass media.
    Sundance 850 Series Optima spa. 1,800 litres (475 gallons). Del Ozone Spa Eclipse.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Anyone used an Ezi-Action Drum Pump?
    I've used similar, and not knocking your idea, but it is a bit more trouble. They make a spiggot for pails that allow you to drain out what you need into a measured pitcher or other vessel. Just a thought...
    Essential Links:
    Feb 2015
    18
    That sounds interesting. Do you have a link to what that looks like or where I could look to purchase one?
