Thread: Need to raise CH 250ppm best dispersal method?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Thanks to what I've learned here I have managed to get my pool chemistry
    to near perfect levels. Just to get an idea my CYA was over 300 when I first moved into this
    house last september..and now it's within the tfp suggested levels. thanks very much for the knowledge!
    One last item though as the partial drains and refills have all but depleted my calcium levels.
    right now CH is 50 and pool math says to add 39 lbs of calcium chloride to get it to 300ppm.
    I'm going to buy 50 lbs of that from the nearby pool store (they have very fair pricing on chemicals)
    1. Should I mix the calcium chloride in buckets with pool water and dump it in different areas or dump through the skimmer?
    2. or should I disperse it using a big cup to just throw it in and sink down into the pool?
    3. how long can i expect the CH readings to take effect once I've added? days, hours weeks?
    I was planning on adding 25 lbs first then testing to see what happens.
    Dolphin E10 Cleaning Robot.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would dissolve it in a bucket of water first. Just add enough so you can get it all dissolved. Then pour it front of a return with your pump running.
    You can test for it in an hour.
    Jeff
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Need to raise CH 250ppm best dispersal method?
    I've poured it in then brushed down the pool.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    thanks for the tips
    I'd read somewhere that you shouldn't mix more than 3 lbs at a time per gallon bucket of
    water due to the chemical reaction that takes place and heats up the water.
    I did that and boy did that bucket get really warm every time. I think it also helped
    dissolve the calcium chloride. Not a single granule of it was poured into the pool.
    (there was just a little bit on the bottom of the bucket each time)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good Job Borjis!
    That's goal when possible any time your adding a solid substance to the pool. Never good to risk anything lying on the bottom.
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Nice job Borjis !
    Jeff
