Results 1 to 8 of 8
Thread: Daily chlorine tabs to bleach
    New member... great site!!!
    I am currently using (2) 1" quick dissolving chlorine tabs in the skimmer basket on a daily basis for sanitizing. I would like to begin using bleach, however, I can not determine how much to use on a daily basis. I have viewed the pool calculator, however, I can not figure out how many ounces to use for daily maintenance.
    Pool is 12x24 and approximately 7,700 gallons.
    Thanks for the help!!
    12x24 Semi IG pool
    1.5hp Pump, Cartridge Filter
    SE Minnesota
    91
    Re: Daily chlorine tabs to bleach
    To determine how much you need, you have to know what your CYA levels are at. If you are using pucks, they all contain CYA and you have been adding more each time. The amount of chlorine is all based on size of pool and CYA levels.
    Mona SE MN
    24' round 48" high AG
    Meteor Sand Filter
    1.5 HP pump
    Jun 2008
    Marana, AZ
    347
    The first thing you have to do is test your water for how much chlorine you have. Then you have to know what your target level is; that's what's based on your CYA level. There's a chlorine - CYA chart in the pool school. Then you just plug into the pool calculator the gallons your pool is, what your current chlorine level is, what you want it to be, and the percentage of chlorine your bleach contains, and you get your answer how much you need to add. Also, that little thing at the bottom of the pool calculator that figures out how much ppm the chlorine will raise your pool is helpful. The relationship is the percentage of chlorine in liquid chlorine raises the ppm in a 10,000 gallon pool per gallon, BTW. Therefore, a gallon of 6 percent bleach will raise the chlorine level in a 10,000 gallon pool by 6 ppm; a gallon of 10 percent liquid chlorine will raise the chlorine level in a 10,000 gallon pool by 10 ppm; etc. And once you figure out how much chlorine your pool takes per day, you will end up adding about the same amount per day. So you don't have to keep figuring. And you will memorize a few things. Like with my pool, I add about 1 cup 10 percent liquid chlorine per day, because it uses not quite 1 ppm a day and it's 9400 gallons. I also sometimes will add about 1/4 cup of cal-hypo instead of 1 cup of chlorine. I also know that if I miss a day, I usually drop a little more than 1 and a half ppm, and therefore, I add between 1 and a half and 2 cups liquid chlorine. And I've only been doing this for a couple of months; you get to know your pool's demands extremely quickly. You also control your levels a lot better than you can with tabs in a floater.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    I am finally figuring out how much to use for maintenance, it took a few weeks. I had to test regularly with the TF-100 test kit, it gives a much more accurate clorine level. Then I would punch in what the levels for free clorine and cya were, and put in the level I want to be at and came up with the number of ounces to add to get to the desired level. If you read the posts here you will constantly see people urging a good test kit. I was hesitant at first, but it is the best thing I have done so far! I no longer have to go to the pool store at all!
    Sharkline 18x33 54"AG, Hayward 1.5hp Perflex D.E., TF-100 test kit
    Finally....a pool of our own!
    Good point Swimgirl, I need to determine is how much chlorine the pool uses each day.
    Thanks all for the helpful imformation.
    12x24 Semi IG pool
    Mar 2007
    San Rafael, CA USA
    12,082
    Two 1" (3-ounce) Trichlor tablets would raise the FC by 5.3 ppm in 7700 gallons. That sounds like a rather high daily FC usage so you might be fighting nascent algae already. Either that or the tablets are a lot smaller than I assume (i.e. < 3 ounce weight).
    That right.
    I have noticed some algae since I started using the 1" tablets.
    What is nascent algae? Am I over chlorinating?
    Thanks
    12x24 Semi IG pool
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by Louserio
    That right.
    Thanks
    I would describe Nascent algae this way: Algae is trying to take hold in your pool, you can't really "see" it yet, you can tell it's there when you have proper testing in place. You will see a large drop in free chlorine overnight, or you may have a high CC level, it's usually suspected when one has trouble keeping free chlorine in the pool, as the algae is consuming the chlorine as soon as you add it, like you are staying one step ahead of it, so your pool hasn't turned green yet. Alot of times pools that have nascent algae are a bit cloudy or just on the verge of a greenish tint...
    As to overchlorinating, it would be helpful for us if you posted a complete set of test results. Then we can advise you better.
