Results 1 to 18 of 18
Thread: New filter and Pump Question.
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    I have a Lomart 18x52 above ground pool, I need a new filter and pump.
    Is this filter and pump large enough for this pool?
    http://www.amazon.com/dp/B000EVNZLQ/...PSXI71VG&psc=1
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: New filter and Pump Question.
    It will work, but may need back flushing more often.
    Here's the manual: https://www.hayward-pool.com/pdf/manuals/Manual145.pdf
    Check out pool school here's some reading: http://www.troublefreepool.com/conte...f-pool-filters
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Why would it require back flushing more. What would be a better option?
    I read through the pool school, Thanks!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It'll need more frequent back flushing do to it being the min size for your pool. Not to say it won't work.
    A 21 inch filter would mean less back flushing due to it being bigger than the 18 inch.
    I would recommend a 1 hp 2 speed pump, power flo matrix, with a larger filter than the 18 inch. You'll save money on your electric by running your pump on low speed most of the time. Now you may not find that in a combo package in that configuration. You can purchase each separate.
    Jeff
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    I will look into that. Thank you for what exactly what I need, I've been having a hard time finding what I need.
    Would something like this be something to even look at or should I stick to Hayward?
    http://www.amazon.com/4500GPH-Filter...3PVZN1T4NQRZZ6
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes that will work. Now with that said, that pump is too big and the filter is not that much bigger than the 18 inch. This is the problem with the combo packages. The pump is oversized, too big and the filter too small. Way too much pump for your pool.
    The best way to go is the Hayward 21 inch filter and the Hayward 1 hp 2 speed Power Flo Matrix pump. That is a very good pump that a lot of folks use with an AGP. I use one and it's a great pump. Low speed is plenty and you save on your electric bill. I only use high speed when I vac or I need the skimmer to remove more floating debris.
    Jeff
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Next newbie question (thanks for helping)
    Where is the best place online to get this stuff. And do you have a part number for the pump, all I'm finding is 1.5 hp 2 speed.
    Apr 2011
    Murrieta, CA
    2,360
    Hello,
    For energy savings you should go with a 2-speed motor/pump, with pool pumps bigger isn't necessarily better. It's better to have a lower horsepower pump and a larger filter. (A lower horsepower pump equals energy savings, and a larger filter requires less cleaning.)
    FROM: http://www.greenbuildingadvisor.com/...ool-energy-hog
    If you reduce the speed of a pump motor by half, you get half the water flow, so you will have to operate the pump for twice as long as you would if you used a pump with a more powerful motor. But since the low-speed motor only draws one-eighth as much power as the high-speed motor, it will only require one-quarter as much energy (in theory; actual savings are somewhat less than theoretical savings) to move the water with a smaller pump.
    If you look at my signature I've got a 3/4 hp 2-speed motor and only a 100ft cartridge filter. It works fine, but the filter needs more cleaning during the summer months. (twice a month in July/Aug).
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The part number is SP15922S.
    Here is an example. A google search will give more results. Look for best price. It's a little more money, but you'll save in the end.
    http://m.ebay.com/itm/Hayward-Power-...-/130887700860
    Forgot to Welcome you to TFP !! My bad.
    Jeff
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Thats so much pwrstrk! I will do it right.
    I have to put the new liner in, foam coves and gorilla pad so I'm sure I will have many more questions for the forum.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Glad to help you out !!
    Keep us posted on how things are going and when you have questions don't hesitate to ask.
    Jeff
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Looks good to me. Now all ya have to do is click buy it now !! Lol.
    Jeff
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Also any difference between the one above and this one?
    http://www.ebay.com/itm/Hayward-S210...3D201162229628
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I really don't see a difference unless I'm missing something. I've just never heard of the sand master. The Pro Series I've heard of.
    Jeff
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    I'll just spend the extra $10 and get one everyone knows just in case.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Sounds good !
    Jeff
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Alright, Pump and filter are here, these things are huge!
    Now I have no hoses or plumbing. How to I hook all this up? What do I need?
    Lomart 18x48 AGP 7000Gal
    Hayward S210T w/Hayward 1hp Power-Flo Matrix Pump 2-Speed
    TF-100 w/Speedstir!
