Results 1 to 13 of 13
Thread: Oval AGP harder to DIY install than round?
    May 2014
    SW Washington
    61
    I feel like I have been spending every waking minute of my life planning this new pool setup and the only actual thing we have accomplished so far is getting trees removed.
    I am still trying to nail down a size that will work. A 21' round is the max we can go and will likely look best in the space (all nicely tucked in the corner). The little voice inside me screaming "Buy the biggest pool you can fit!" would like me to purchase a 15-18 x 30-32. The responsible adult in me thinks I should stick with the smaller 21' round. Many of the threads I have looked over talk about the difficulty in putting up an oval. If it is considerably harder than a round I think that might be the tie-breaker I need. Our marriage was not meant to withstand difficult DIY projects
    21' Round pros: Fits nicely in the yard, easily 1k cheaper than the ovals, more 'structurally sound' (which I get...but has there ever been a wall blowout or other known catastrophe on a properly installed oval pool?), whirlpools!, won't be sitting over root systems of trees we've just had removed
    Oval pros: More gallons of pool to swim in! (that's really about it. But it's pretty compelling.)
    14k Gallon 24' x 54" Signature RTL , 1 hp 2 speed Pentair Optiflow, 350lb Pentair SD80 sand filter, 2" leaky plumbing, a Zodiac G3, and my TF-100!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Oval AGP harder to DIY install than round?
    I had my oval installed, but I can't imagine any more "degree of difficulty" in setting one up vs. a round one. Walls are walls and uprights are uprights............and more importantly........level is level. You can also get 10 feet more away from other "poolsters" in one!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    I agree with woodyp.
    If the Oval is more difficult, thats because there will me more physical labor involved in preparing the ground for it simply due to the larger area.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Nobody here is going to say that a smaller pool is better!
    And i agree that i don't see a logistical reason for an oval pool to be more difficult. I have put up a couple of round pools. Nothing to it, very easy to put together an above ground pool. Leveling the ground? Definitely NOT easy. Of course, that depends how flat and level your yard is to start with. Mine, not so much.
    Casey's Avatar
    SW PA
    10,461
    YouTube oval pool installs verses round ones.
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    I debated this too. An oval has to have more supports on the sides, because the water will always want to push out on those long flat sides. Whereas a round pool there is even pressure spread out equally. The pool I was looking at needed extra supports dug in the ground. It also required 8(?) cinder blocks buried at each side that the supports sit on. My ground is clay, that was hard as cement. So getting a single 2 inch paver block level took about an hour for each one.
    The pool store also made a good point. If you take a round pool, and cut the sides off, that is the swim space you will lose going to an oval. So depending on the length, you could lose some swim space if you go oval. For me the final decision was made when the underground electric went across my yard and would of cost me 3k to get moved.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    May 2014
    SW Washington
    61
    Best discovery ever: I measured wrong and I can actually fit a 24' round I am so excited! The oval was going to cut too much into usable yard space but the 21' round was too small. I didn't feel good about either one. But I will be *supremely* happy with a 24'! My other half is slowly warming to the idea of a bigger 'real' pool. He still doesn't understand why we would need more than our 15' Intex....some people!
    I have been waiting for him to go to sleep to research our next pool purchase (he totally thinks I have lost my mind. Might be true.)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    LOL!
    well Im glad you got it figured out
    good luck!
    Divin Dave,
    Casey's Avatar
    SW PA
    10,461
    You'll love the 24 n he will too! Check out SHARKLINE pools at poolsupplyworld. I love my Venture 54"wall.
    My husband did not want a pool. It took me 3 years to plan the whole thing n make it happen. He's in it everyday!!! If I can't find him, that's the first place I go n he's on his raft soaking up the rays! If it's rainy or cloudy, he complains because it cuts into his pool time. lol He uses the pool more than I do! lol
    Apr 2010
    East Texas
    9,655
    It took me 3 years to "Scheme and Plot" the whole thing n make it happen. Fixed that for ya'!
    Casey's Avatar
    SW PA
    10,461
    Quote Originally Posted by woodyp View Post
    Shhhhhh!
    Feb 2015
    charlotte nc
    2
    oval is much more difficult to install.
    take it from me, i have installed thousands of these pools
    I would not recommend it to a homeowner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by linzjane88 View Post
    I can't speak to the difficulty in installation or blown out walls, but based on your post, perhaps you need to stick with the round. I don't recall seeing a blown out wall oval, but I certainly could have missed that here. If an oval would blow out your marriage...maybe better to go round....
    Essential Links:
