Thread: Jandy/Zodiac RS All Button - Extra Wires on Red 4 pin connector
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    Question Jandy/Zodiac RS All Button - Extra Wires on Red 4 pin connector
    My sister just got a new house and I'm helping upgrade her Jandy/Zodiac RS All Button to an iAquaLink. The current setup has a spa side switch, but it appears that it may be connected to the red 4 pin connector instead of the brown terminal bar as the connector to the brown terminal bar was disconnected (see attached). The only control I found in the house was the RS All Button so I'm thinking that the extra wires on the 4 pin are for the spa side switch (note that I have not yet confirmed if it even works). Thoughts?
    Thanks!
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    Re: Jandy/Zodiac RS All Button - Extra Wires on Red 4 pin connector
    The left most connector in the photo (red?) is the communications port. All of the wired remotes get connected to there. If you have a wireless remote, an antenna module will also connect to there. A few of the Jandy brand heaters also get wired to there.
    May 2011
    93
    Quote Originally Posted by JasonLion View Post
    That's why it is confusing. There are no other remotes or J boxes I could find so the extra wires are a mystery. Didn't know about the heater being a possibility. I will check mine as coincidentally we both have the same heater (Laars LX400). Thanks!
