Thread: Ok to use automated vacuum?
    Nov 2014
    Palm Desert, CA
    99
    It's been a little over 4 weeks since my new plaster. Is it ok to use the automatic vacuum now? Also, I am now brushing every other day instead of daily. Is that ok, or should I do daily for a week or two longer? THANKS
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Re: Ok to use automated vacuum?
    Hi LisaDLu,
    I think you should be ok using your robot now.
    Are you still getting plaster dust when you brush? If you get what you think is a good bit of dust, then I would say brush every day until it decreases, then every other day after that until there isnt any more dust that brushes off.
    Its a lot of brushing I know, but for the sake of your plaster, dont quit brushing too soon.
    hope this helps,
    Quote Originally Posted by LisaDLu View Post
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Absolutely no problem. It's ready to go.
    Essential Links:
