Results 1 to 11 of 11
Thread: ordering a posts
    gtm's Avatar
    Aug 2008
    St. Petersburg, Florida
    201
    ordering a posts
    Hello all,
    I would like that the posts in any individual thread would order from the most recent reply DOWN to the original post. This is mainly because I try to monitor all the new posts and it would save a LOT of scrolling downwards.
    Is there a way to change the default ordering? I looked in the user area for a "preferences" sort of option, but didn't find anything. Maybe I missed it?
    Thanks, Gary
    15,000 gal. IG fiberglass pool w/ 1 hp Hayward Max-Flo and 250 lb. Hayward sand filter
    Located in St. Petersburg, Florida, and enclosed in a birdcage
    30,403
    Re: ordering a posts
    Gary,
    After you log in, go to the "home" screen and try "view new posts" on the right hand side.
    gtm's Avatar
    Aug 2008
    201
    Thanks duraleigh,
    When I do that all the various new posts are indeed in the order that I would like, but what I'm wondering is about changing the order within a thread, such as this one. That is, when you see this one, you'll see my first message, then your reply, then this message. I'd sort of like them in the opposite order ...
    Thanks for the reply. I've read a lot of your posts and have learned a lot. Looking forward to reading more!
    Cheers, Gary
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by gtm
    Thanks duraleigh,
    Cheers, Gary
    When you're looking at the "view new posts" link from the home page, in the far right column it shows the most recent post. There is a little rectangle next to the member's name. If you click on it, it takes you to the last post, instead of starting at the top and having to scroll thru.
    gtm's Avatar
    Aug 2008
    201
    That's great ... Thanks!
    Riles_J's Avatar
    Nashville, TN
    218
    Quote Originally Posted by frustratedpoolmom
    I do not see any little rectangle near the member's name. This sounds like a nice feature, but I can't seem to figure this out? Is there a setting that I need to change?
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Riles_J
    Riles
    Are you in the "view new posts" link from the home page? If yes, the "last post" column is far right. Next to the member's name is an arrow -> and a rectangle.
    You're done SLAMing when:
    Riles_J's Avatar
    Nashville, TN
    218
    In this post this is all I see: (No other characters, symbols or anything.) Am I looking in the right spot?
    Last post Fri Aug 29, 2008 10:40 am
    by Butterfly
    Butterfly's Avatar
    South Carolina
    10,045
    by Butterfly
    It is not an option (located) inside a post.
    After you log on, select "view new posts" button/link located under your avatar on the home page. Once there, you will see the symbols we are talking about.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Are you starting here:
    portal.php
    User the view new posts on the right hand side of that page, not the forum index page.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Riles_J's Avatar
    Nashville, TN
    218
    Ahhhhh! Sean thanks, that was it. I have been using the View new posts from the Index page instead of the home page.
    Thanks!
