Thread: Air compressor aerator
    Jul 2010
    Double Oak, TX
    44
    reference point: http://www.troublefreepool.com/threa...orching-hot-PA
    First a question - If you look at the picture of the aerator in operation you'll see lots of very small bubbles released through the soaker hose attachment. Is there benefit to having several thousands of small bubbles aerating the water as opposed to a single outlet at the end of a garden hose shooting fewer large bubbles?
    Second - several folks asked about how to build the adapter between the pressure hose and the garden hose. Like AlBundy59 I went to Lowe's and got some help. Here are the parts I have: 1/4" Brass NPT plug adapter into the pressure hose; 1/2" FIP x 1/4" FIP (brass), 3/4" MH x 1/2" MIP (brass). That last piece will let me screw the garden hose onto my air pressure hose.
    35K gallons, StaRite S8D110 DE Filter, Pentair IntelliFlo vs3050 pump, IG gunite
    Re: Air compressor aerator
    Many small bubbles are much much better than fewer larger bubbles. Technically, it is a function of surface area. Larger bubbles have less surface per volume of air, smaller bubbles have more surface area for the same volume of air.
