Thread: Are there any additional circuit inside the pool housing?
    Jan 2015
    San Jose, CA
    237
    My Pentair housing has a leak blowing out my LED lights. When I tested with a regular 120v bulb, I'm not getting any power, I put a meter to the socket and get no reading. Since it's a 120v I'm wondering if there is anything else in there that may have fried where I'd have to replace the entire housing.
    I've tested the switch and there's current going through the wires.
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    Re: Are there any additional circuit inside the pool housing?
    There is often a thermal cutout switch to prevent overheating in the base of the fixture, though not always. Typically they are epoxied into the base of the fixture, so you can't always tell if there is one or not.
    Jan 2015
    San Jose, CA
    237
    Yes I do see the thick epoxy base, there's also a loop of coil that runs across with this pencil looking thing that pop out.
    Would I need to drain the pool to pull out the old wires and snake new one in?
    SF Bay
    You do not need to drain the pool, though a partial drain has some advantages. Basically, you will need to have your arms in the general area of the light niche a fair bit, i.e. in the water, if you don't do a partial drain, which can be problematic if the water is very cold.
