Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: My First TFT test
    Jan 2015
    TX
    49
    My First TFT test
    Hi guys finally got to doing the full test today
    Let me know what I should do
    Cl= 5
    Br= 10
    PH= 8.2
    FC= 13
    CC= 1
    CH= 600
    TA= 140
    CYA= 40
    TX/Dallas | 18K ? gal. | Plaster | Jandy valves, Jandy panel, Aqualink RS4
    Pentair Challenger Fixed 2hp | SWG AquaPure PLC1400*repl 2015 | Pentair Clean & Clear 420
    ThePoolCleaner 2wheels
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: My First TFT test
    Quote Originally Posted by zacc44 View Post
    Cl= 5
    Br= 10
    PH= 8.2
    FC= 13
    CC= 1
    CH= 600
    TA= 140
    CYA= 40
    A few things spring out at me.
    1) If you did the FAS-DPD powder test, you don't need to do the yellow OTO test.
    2) You can see a discrepancy. One says FC is 5, the other says 13. Oops. Believe the 13.
    3) Unless you're using Bromine as a sanitizer, that reading is useless. Ignore it.
    4) With FC above 10, your pH reading is reading falsely high. Don't add acid to lower it, or you'll go too low.
    5) Repeat that FC & CC test. If CC is really 1, something isn't right.
    6) Your FC is a bit high for your CYA level. Are you in the SLAM process, killing algae? If not, you're too high. It probably won't hurt anything but it will be rough on swimsuits.
    7) If you're running a saltwater chlorine generator, your CYA level needs to be raised.
    8) You forgot the most important part -- what does the water look like? The only people impressed with your readings are here. Your guests only care about how clear the water is.
    Have you read the ABCs of Pool Chemistry, Water Balance for SWGs and How to Use Poolmath? Start there. Also turn down that SWG so you can get an accurate pH test. Try the tests again in a day or two, and if the CYA is still only at 40, plan to raise it. Adjust the pH as soon as you get a reliable pH test result. Lowering pH regularly will eventually lower your TA to a stable respectable number. You don't need to obsess on it. You can't do much about high CH if you live in a hard water area. Get the pH, CYA, and FC under control. By then, you'll understand how things work a little better and you'll probably be able to figure out everything else on your own.
    Jan 2015
    TX
    49
    i have been busy and havent had time to do much to the pool except skim and brush it (and it stayed looking good)
    weve had some rains here and temps are up so i retested to see what its like
    water temp 71F
    water looks nice and clear just like before
    doesnt smell like chlorine
    ph = 8.2
    FC = 3
    CC = 1 (i dont know maybe im looking too critical)
    TA = 110
    CYA = 25
    38,524
    PH way too high. Fix this first.
    Cya too low ... Which will require raising the FC when fixed. Although it may correct itself when less FC is lost to the sun.
    Jan 2015
    TX
    49
    awesome thanks,
    i also got the lezliezpool salt strips and they indicated salt level about 3500
    Jan 2015
    TX
    49
    ok so i added some muriatic acid and then some CYA
    should i have done the dichlor or trichlor instead? ... but i mean isnt the SWG supposed to make chlorine?
    ph = 8.2 --> 7.5
    FC = 3 ----> 2
    CC = 1 ----> 0.5
    TA = 110 --> 100
    CYA = 25 --> 40
    38,524
    Yes it should. If there is nothing growing in the pool and the sun is not destroying it.
    Jan 2015
    TX
    49
    This was like 3days after the acids, should I wait more or do I need to fix the chlorine?
    38,524
    Well, 3 day old test results are not very helpful.
    If the FC is ever too low you should immediately raise it with bleach.
    How much CYA did you add? What was your target?
    Jan 2015
    TX
    49
    I just tested
    PH 7.9 (up again)
    FC 1 ... guess I'm gonna add some chlorine, I wonder if the SWG is broken
    CC 0.5
    TA 100
    CYA 45
    38,524
    Looks like you are only testing (or at least only posting) every 3 days ... that is not going to cut it while you are trying to straighten out your pool.
    What does the water look like?
    Jan 2015
    TX
    49
    I started testing weekly seemed stable until I added the Muriatic acid/or weather got hotter, and the chlorine started to drop
    The water looks great just like in the winter
    It tastes more salty today but no chlorine taste/smell
    Last night I added ~60oz of Clorox 8% (pool calc estim 64 for goal of 4)
    12h later
    pH still 8
    FC 5
    CC 0.5
    TA 110
    CYA 45
    38,524
    With a SWG and high TA, you just are going to have to keep adding acid.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Are you running any waterfalls or bubblers? Those will increase your too. Chlorine consumption increases as sunshine and temperatures increase. Can you increase the output of your SWCG? Or increase the run time of the pump so the SWCG runs longer and makes more chlorine?
    Jan 2015
    TX
    49
    the attached spa spills over into the pool so it is kind of a waterfall
    i increased the time from 6h overnight in winter to 12h total hours (3h runs with 3h breaks in between - this seems to skim the pool real good)
    i just increased the SWG from "40%" to "50%"
    DFW, TX
    24,514
    Ok, keep testing chlorine until you get it dialed in. Has it been a week since you added cya? If so it is time to test it again. 45 is too low, need to get it up to 60-80. It takes a week for cya to fully dissolve and read correctly on the test.
    Here is some info for you to read on water chemistry and levels for a saltwater pool.
    ABC's of Pool Water Chemistry
    Water Balance for SWCGs
    PoolMath, will tell you how much to add to adjust your levels.
    Jan 2015
    TX
    49
    still dont have a handle on the SWG keeping chlorine stable, but its been raining and what not...
    here's today's tests after all the rain (i added a jug of clorox last night when cl was 1, and some muriatic acid)
    Cl = 5
    pH = 7.6
    TA = 50 - poolcalc says add 211oz NaHCO3 for goal 60-80
    CH = 200 - poolcalc says to add 160oz of CaCl for Goal 250-350
    salinity = 2400 (my SWG says goal is 3000)
    CYA = 30
    30,432
    What is your CYA?
    Jan 2015
    TX
    49
    got worse CYA = 30 (guess from all the rain)
  20. Back To Top    #20
    38,524
    Have you Performed the Overnight Chlorine Loss Test to make sure there is nothing in the water consuming the chlorine?
    I would do that. If you pass, then raise the CYA up so that the SWG has some hope of maintaining FC levels.
