Thread: Leaking at the Pump?
    I have a Hayward paper filter and the PVC plumbing to a pad next to it with a Hayward impeller and Emerson motor. I had Leslie's install it a few years ago. It is relatively new and works fine. I have a little protective housing covering it.
    I have a leak when I look at the concrete pad by the motor. I checked all the PVC and it is dry. It seems to be near the motor/impeller on the bottom. The motor has a fan below you can see air moving.
    I think there is a rubber seal between the impeller and motor. I am thinking of tightening the bolts between the two units. It is a small leak but I am stumped. Thanks for any help.
    The tag line below is wrong. It is a smaller pool with a single speed motor.
    23,000 IG plaster pool, hayward 2 speed 2.5 hp pump and 550 sq. ft. cartridge filter, SWG, Polaris 360
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Leaking at the Pump?
    Might be the shaft seal. Their inexpensive overall. Maybe $10 bucks or so. If you can provide the pump info Model and such might be able to provide more info.
    Quote Originally Posted by bobodaclown View Post
    It is a Hayward SP and I cannot see the model number on the cheap foil model and serial number. I tried to upload a picture but they only accept small file sizes. Is it a rubber seal between the motor and Hayward impeller? Thanks.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Hi, On the black plastic housing of the pump is a black and silver label. it should be on the side near the basket. It should have a model and serial number. I can get the seal model number for you then. I will also Private Message you my email address and you can send a picture.
    John the Hayward tech.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    38,239
    It is a 2 piece ceramic seal that spins between the motor and the impeller on the shaft.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    If your pump is a Hayward Super 2 then you would need the AS-1521 standard shaft seal or the PS-3868 heavy duty seal for saltwater pools. These seals are easy fxes, with plenty of guides online to show you how to replace.
