Thread: Pump start time?
    Oct 2014
    Tujunga, CA
    109
    Pump start time?
    Hi guys,
    My salt water pump is programmed to run from 1pm to 9pm 7 days a week. Will it cause any harm to the pool if I change the pump times from say 6am to 2pm? My thoughts are that on the 1-9pm schedule it will be at the peak electric usage time, especially in the summer here in Southern, CA. I have Jandy equipment.
    Thoughts on this?
    Emil
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Re: Pump start time?
    Hi emil,
    you can run your pump however long you feel you need to and whatever time you need to.
    The best advice I can give you is to read this. Its a great reference.
    http://www.troublefreepool.com/conte...-pump-run-time
    Since you have a saltwater pool, you need to measure your FC a couple of times a day and lean how much chlorine your SWG is making during the pump time, and then adjust accordingly.
    Divin Dave,
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    You might also consider splitting up your pump run cycle (i.e. chlorine generation in your case) to two or 3 separate cycles with a timer if it helps keep your FC more uniform.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Quote Originally Posted by emil View Post
    Thoughts on this?
    Hello Emil, no harm switching times. You could break up your times if you want to avoid peak usage.
    Ensure you're maintaining the proper FC/CYA levels. http://www.troublefreepool.com/conte...art-slam-shock
    Oct 2014
    Tujunga, CA
    109
    Thanks for the info!
