Results 1 to 13 of 13
Thread: Unusual Freezing Temps
    jhawk19's Avatar
    Feb 2015
    York
    16
    Hello All,
    This is my first post. My pool was installed in November and filled up in December. I live in SC and have a 16,000 gallon pool. I have freeze protection set to 38. I have a 3600ppm salt level. Temps this week have been COLD. Tonight it's supposed to get into single digits and the pump has been running all day. Tomorrow's high is 39. Do I need to be concerned?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Unusual Freezing Temps
    About plumbing freezing? No.
    jhawk19's Avatar
    Feb 2015
    York
    16
    Excellent! Anything else I need to be concerned with?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Welcome to TFP,
    If it were me, I would wrap something like old towels, or old blanket around the above ground pipes. A put a tarp over the pump and filter, and put work light, under the tarp to give it a little heat.
    Better safe than sorry.
    Divin Dave,
    mas985's Avatar
    Pleasanton, CA
    11,737
    The automatic freeze protection can and does fail. As Dave suggested, tarp the equipment and put a light bulb underneath. Better yet, just drain the above ground plumbing.
    This thread might be of some interest:
    http://www.troublefreepool.com/threa...eze-Protection
    Mark
    DFW, TX
    24,485
    We rarely get into single digits, but we got to 9 last year along with 3 or 4 days with highs in the 20s and we had no issues, other than being COLD. Not even ice on the pool surface. We've had plenty of temps in the 20 and upper teens with no issues ever. I think because we don't have sustained periods of cold that the ground and gunite don't get cold enough to freeze. Probably the same in SC.
    jhawk19's Avatar
    Feb 2015
    York
    16
    It's too late and too cold to drain the above ground plumbing. I did wrap the plumbing with some towels. I'll let you all know how it turns out tomorrow!
    38,275
    Better hope for no power outage
    jhawk19's Avatar
    Feb 2015
    York
    16
    No issues! Everything is running smoothly. Water temp is 36 and climbing!
    16,000 Gallon 450sq ft Freeform Sport Pool (3.5' - 5.5' - 4') - Sheer Descent - Exposed Beam - Greystone Coping - Aqua Blue PebbleSheen - Jandy Pro Plus HP Pump - Jandy Pro Series Cartridge Filter - Nature2 Fusion Soft
    DFW, TX
    24,485
    Quote Originally Posted by jhawk19 View Post
    Not fast enough!!
    We did have a power outage once a couple of years ago for about 36 hours. Lots of stuff froze and it sucked a lot. But, we thawed it out and everything worked fine. Nothing you can do about that though. That light bulb under the tarp is not gonna help any!!!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Right! Which is why under those type of conditions the only way to truly protect the equipment and plumbing is to drain it of water.
    But it does prove that freezing does not always cause damage. In fact, in most cases it won't cause damage unless it freezes in a particular order.
    Mark
    jhawk19's Avatar
    Feb 2015
    York
    16
    Thank you guys. Great information. Happy to be here.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Well I'm happy that I'm not there. It's was 75 and sunny here today. I was just out cleaning my filter and getting the pool ready for summer.
    chiefwej
