Results 1 to 8 of 8
Thread: How much lube to use ?
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    How much lube should be used to lube an o-ring? Sparingly or generously?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: How much lube to use ?
    You gotta get that just right. I assume it is in pool plumbing somewhere? Don't need a bunch extra squeezing out. Really the goal is just enough to get it to slide into place without binding up.
    Sep 2013
    810
    I am trying to find out where I am getting air from because my pump basket gets a good amount of air in it. I've already replaced the drain plug O-Rings, and put Teflon tape on them. Today I cleaned and re-lubed the basket o-ring.. but I'm still getting air. I've tried both sparing and generous amounts of lube but neither makes a difference. Next I'll have to try replacing the O-rings on my 4 month old jandy "neverlube" valves for the main drain and skimmers. Brand new pool, but PB ceased all communication and all of his techs claim it's normal operation. You should see how much air gets in there. It's definitely not normal.
    DFW, TX
    24,497
    I can't imagine that it is a pump o-ring or valve issue. Much more likely that it is between the skimmer and the pump or main drain and the pump. Can you isolate one or the other? Might help narrow it down.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Lube enough to get the job done no more/no less.
    You can use running water (steady stream/not full blown jet), over the fittings/connections to help isolate the leak, or shaving cream, foaming/not gel.
    Run water/or place shaving cream on fittings and such, keep an eye on the basket and watch for the air bubble to dissipate, go slowly.
    With the shaving cream you can watch it get sucked into the leak.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Also check the threaded Union that ties into the suction of the pump.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Sep 2013
    810
    Quote Originally Posted by pooldv View Post
    Makes no difference whether it's set for main drain or one or the other skimmer, I still get air and turbulence. I'll have to try the shaving cream.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    how much air? pictures?
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
