Results 1 to 8 of 8
Thread: Wood platform for salt water pool
    Feb 2015
    Seattle, WA
    16
    Hello,
    I'm moving to a home with a salt water pool and will use it extensively for hydrotherapy for my German Shepherd. That means he needs a platform to stand on when not swimming. This might sound a little strange, but I have a coffee table that's the perfect height to keep his legs underwater when standing on it, but his upper body above the water line. I'm hoping to use the table as it would be tough to create my own platform with more salt-water-resistant materials given the specific height requirements I want.
    My question is what type of damage might the salt water cause and how quickly (the table is heavy enough it isn't practical to take it in and out)?
    Also, does anyone know of a wood treatment that might prevent, or at least slow down, corrosion but won't contaminate the pool?
    Thanks!
    Jonesy
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Wood platform for salt water pool
    Real wood, especially hard wood like oak or maple, will hold up reasonably well under water. Probably better if you leave it it in than if you you take it out. But, big BUT, is that coffee table solid wood? Or is it particle board with veneer or laminate? If it is particle board it will swell up and disintegrate quickly. Teak or ipe will hold up well also. If you are going to make something you could use a composite decking material. Use water proof glue and stainless steel screws or ceramic coated screws.
    Jan 2015
    NSW Central Coast AUSTRALIA
    36
    If it's solid wood it will last under brackish water for maybe hundreds of years, especially if it is something like oak. If you're ever in Sweden check out the Vasa, an amazing ship that was underwater for hundreds of years and has now been salvaged and put on display. If you want to build a table that will last underwater make one out of Turpentine.
    7700 Gallon Bestway 22ft Vinyl, Zodiac Clearwater 170 SWG, Sand Filter, Hand Vacuum, Borates.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    To make it last better, coating it in epoxy would be the preferred approach...works well on sailboats
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    30,431
    As a VERY broad based answer, wood does not rot underwater much at all.
    The glue will come loose, the steel screws will rust and laminate will de-laminate.
    The advice above for stainless screws and solid wood will all outlast your needs if you keep it in the pool.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    The only concern I would have is with the non-organic parts of the coffee table, e.g. nails/screws/glue, varnish, stain, etc. Any real wood will be fine. Any components that are not wood could rust, dissolve into your pool water, or otherwise create havoc. If you find that it stays together and that you don't see colors leaching out into your pool water, then it might work.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Solid Redwood with high quality SS screws/hardware would out last you.
    Essential Links:
    Feb 2015
    Seattle, WA
    16
    Thanks, guys! I feel pretty good about it now as it is solid wood. There are some metal components but I can remove them without damaging the table integrity.
