Thread: Elevation of pool pump
    Oct 2013
    Managua, Nicaragua
    11
    What is the ideal height of the intake port on a pool pump in relation to the water level in a pool? Level with the pool water, two inches below....?
    My pumps are Pentair 3 HP variable speed pumps. Thanks in advance.
    Outskirts of Managua, Nicaragua. 50,000 gallon in ground 60' x 20' poured concrete pool with an attached jacuzzi, deep end of 9' 4", shallow end of 4'. Two Pentair salt water generators, two Pentair Intelliflow XF variable speed 3 HP pumps, two Pentair Clean and Clear Plus 520 sq. ft. cartridge filters, two Pentair Intellibrite LED pool lights, one Pentair Intellibrite LED spa light.
    38,235
    Re: Elevation of pool pump
    It does not matter very much. If it is a self-priming pump it can be quite a bit above the water level. If it is not (like an above-ground pump), then it must be below the water level.
    If you have the inlet pipe right at the water level, then you would never lose prime because the basket would stay full even when you open it. This also points to the fact that you do not want the pump lid to be below the pool water level since when you open it, water would continuously spill out (unless you added shut-off valves).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Ours is slightly below, maybe a few inches, and it is kinda handy because it is sort of self flushing when we clean out the basket. We can dunk the basket up and down and the outward water flow helps clean out the basket.
    Oct 2013
    Managua, Nicaragua
    11
    Excellent. Thank you very much.
