Results 1 to 19 of 19
Thread: Any regrets switching from Chlorine to a SWCG ??
    Feb 2014
    Upstate, NY
    390
    Ok here is a question for SWCG pool owners. Anyone have any regrets switching from chlorine to a SWCG ??? Is it really that much easier to maintain water balance ?
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Any regrets switching from Chlorine to a SWCG ??
    No regrets here! After about a month of manually dosing, figured it would be easier overall, and it has been.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The only part of the Balance that might be or seem easier would be the maintenance of Free Chlorine. The easy part here coming from a reduced need for handling and adding a product for it. As for it being easier this is about it. You still have to monitor just as frequently and be just as diligent about all your chemistry. Perhaps even a little more so with regard to pH and FC in general until you have a very good feel for how your pool behaves.
    Essential Links:
    No regrets at all, I love my SWG.
    While it isn't a huge difference, it feels much much simpler. We still go out to the pool daily, clean the skimmer and test the water, but there is no more daily chemical additions and no more carrying bleach home from the store.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    I travel frequently for work. With proper planning, I was able to leave my SWG pool completely unattended for up to a week at a time with no problems.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Feb 2014
    Upstate, NY
    390
    Thanks everyone for the replies. Great info.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Absolutely love my SWG.
    Divin Dave,
    Oct 2007
    Parkland, FL
    752
    I love mine too, I'll love it even more when it actually works everyday once I fix the melted parts No getting chlorine and risking staining the car, no opening my wallet to buy said chlorine and no remembering to put chlorine in.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Jul 2012
    Saugerties, NY
    447
    I typically deal with 50-100 pools per week, and I would recommend a SWG to just about anyone. Once you get a feel for the system, a SWG makes life pretty easy.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Feb 2014
    Upstate, NY
    390
    Thanks again everyone.
    Mar 2007
    Murrieta, CA
    215
    The only down side is cost of replacing the cells. My SWG is extremely convenient, when it works.
    I'm on my third cell in about 7 years. Each one has lasted less than two years. This will be my third season with my current cell, so I'm keeping my fingers crossed.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    mas985's Avatar
    Pleasanton, CA
    11,743
    No regrets either. My cell has lasted 9+ years which I can only attribute to strictly following the TFP methods. Good chemistry balance = long cell life.
    Mark
    Jul 2012
    Saugerties, NY
    447
    Quote Originally Posted by peterl1365 View Post
    You shouldn't be going through cells that fast. A cell should easily last 5 years, usually longer. What percentage are you running your SWG at? Have you tried acid dipping the cell?
    TreeFiter
    Pool Technician
    Saugerties, NY
    Feb 2014
    Upstate, NY
    390
    Thanks again everyone. Just to confirm, the Aquarite T15 should be good for my 18,000 gal pool correct ??
    mas985's Avatar
    Pleasanton, CA
    11,743
    Yes, that is fine.
    Mark
    Mar 2007
    Murrieta, CA
    215
    Quote Originally Posted by TreeFiter View Post
    I wish my cells lasted that long. My first cell lasted 18 months and was replaced under warranty. My second lasted 2 seasons (failed due to persistent low-salt readings), after which I switched to tabs for a year or two. Finally bit the bullet and purchased another cell 2 years ago.
    I've cleaned each of my cells multiple times. Usually, there is little or no bubbling that would indicate a scaling issue. I generally operate the cells at 20-30% duty cycle, with the pump running about 12 hours/day. I usually check pH once a week nowadays and do a pretty good job of maintaining it between 7.5 and 7.8 with the help of borates. When the pool was new, I checked at least twice a week because the pH was constantly rising.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    My only regret is not having one installed on my prior pool.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jun 2011
    Long Beach, CA
    2,790
    If you are having to clean the cells often, then your water balance is out of our recommended ranges for a SWG pool. Each cleaning of the cell will reduce its life span and could easily explain why you are not getting the proper life out of the cell. I recommend for you to research our recommendations and start a new thread of your own if you have any questions.
    Mar 2007
    Murrieta, CA
    215
    Quote Originally Posted by ping View Post
    I'm pretty certain my water was reasonably within normal ranges. My CSI calculations always produced very satisfactory numbers. While I say I've cleaned them multiple times, I've actually cleaned them LESS FREQUENTLY than recommended by Pentair. Plus, the last 2 or 3 cleanings per cell, out of maybe 5 or 6 total, were done AFTER the cell started developing problems.
    As it turns out, I had another situation this year. I reconnected my IC40 after unplugging it for the winter. Salt readings were very low (2550 ppm). I confirmed my salt levels to be within optimal levels (~3200ppm) at the pool store, but I added a bag of salt anyway hoping to get the readings to above 2600 ppm so the cell would at least operate. Unfortunately, the readings didn't budge. 1 bag in my 12000 gal pool should have raised the level by 300-400 ppm.
    I replaced the flow sensor (which contains a temperature sensor) and my salt readings instantly went from 2500 PPM to 4000 PPM. So it turns out that it definitely was a hardware issue with the cell.
    Interestingly, a tech rep from Pentair emailed me in response to an online support request. He tried to tell me that 2500 ppm was in the normal range for my water temp (~60 degrees F). He said that the IC40 salt readings vary by 70 PPM per degree of water temperature, and that the cells were calibrated at 77 degrees. Now, that may be true, but it begs the question as to why the IC40 cannot reasonably compensate for that temperature dependence IF IT HAS A TEMP SENSOR BUILT IN.
    Anyway, I'm glad that I don't have to purchase another $500+ cell this summer (knocking on wood). I'm beginning to suspect that my last cell had the same issue, because it started to read very low salt (under 1500ppm) just before it quit working. I didn't realize at the time that the problem could have been fixed by replacing the flow sensor.
