Thread: "Abbreviated" calcium hardness test ration help please
    Feb 2014
    santa barbara, california
    56
    Is this the right amount chems/proceedure to use for the CH test with the TF-100 test kit?
    fill cylinder to 10ml mark with pool water
    add 10 drops R-0010
    add 3 drops R-0011L
    add R-0012 1 drop at a time until color changes to blue, multiply x10 for CH
    thanks, Brian
    title should'a been ratio, not ration(but I guess it does help ration the chems)
    15,000 ig plaster (kidney shape approx 30'x16'), Hayward 1.5hp "Max-flo" pump, Hayward DE filter(48 sq. ft effective filtration area, 96gpm, 6lbs DE), TF-100 Santa Barbara, CA
    38,520
    Re: "Abbreviated" calcium hardness test ration help please
    If you use 10ml, then you multiply by 25ppm
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Quote Originally Posted by calstar View Post
    add 10 drops R-0010
    add 3 drops R-0011L
    thanks, Brian
    Like Jason said, multiply drops by 25. I find it easier to read with 5 drops of R-0011. And blue means sky blue, not lavendar. If you don't have a speedstir, expect it to take close to 10 minutes if you have real hard water. You need to mix it well, really really well. When I switched to using the speedstor, my CH readings dropped by about 200. Same water.
