Results 1 to 10 of 10
Thread: NEW Equipment Suggestions
    Oct 2014
    Modesto, CA
    4
    First-time poster, forgive me in advance, for limited knowledge of pool equipment and jargon
    Bought this house a few years ago, and my pool equipment is in need of an overhaul, looking for some guidance.
    Current Setup
    PUMP
    Replacement Series/Hayward RS1000
    I replaced the seals/gaskets recently
    Motor
    AO SMITH K48L2N104
    1 HP
    115/230 volts
    60Hz
    FILTER (relatively new)
    Hayward C17502
    120 GPM
    BOOSTER PUMP
    3/4HP 3450 RPM 115/230V 56Y Arneson Vertical Pool Cleaner Motor Century # B663
    really loud, not really working anymore
    SWEEPER
    Polaris 280 Vac Sweep
    POOL
    In-Ground
    20,000 gallons
    1.5" pipe to and from equipment
    Returning Jet #1 is strong, #2 is ok, #3 is pathetic.
    I'd like to join the returning line and the booster line (with a valve), if posssible , with a 2-speed or VS pump
    any feedback would be great.
    A pic of my (anchient setup). also, can I ditch the booster pump, and run my Polaris from the new pump?
    [IMG][/IMG]
    [IMG][/IMG]
    Hopefully the pics showed, and hopefully all this makes sense.
    thanks
    ~20,000 gal outdoor gunite (1.5" pipe to and from), Replacement Series/Hayward RS1000 (AO SMITH K4SL2N104 1 HP), Hayward Filter C17502 120 GPM, 3/4HP 3450 RPM 115/230V 56Y Arneson Vertical Pool Cleaner Motor Century # B663 (booster), Polaris 280 Sweep
    Re: NEW Equipment Suggestions
    Welcome to TFP!
    Keep in mind that a Polaris 280 won't work from the main pump, it requires a booster pump. There are other cleaners that will work off of the main pump.
    The returns are probably plumbed sequentially off of a single pipe. Assuming you aren't going to dig up all of the plumbing and replace it (very expensive) the best solution is to put a very small return eyeball on the first return, a mid-sized return eyeball on the middle return, and a large return eyeball on the last return. That will help even out the relative pressure (though it is unlikely to ever be perfect without replumbing).
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Hi, welcome to TFP!
    We hope we can help you find some answers or recommendations that are suitable to you.
    The pump -
    At minimum, go with a 2 speed pump.
    Considering that you are in CA, where electric rates are expensive, a VS pump should definitely be considered.
    Depending on exaclty which model of VS pump you consider, you could do away with at least one of those timers too. Most (but not all) VS pumps have a timer built in.
    the Booster pump - again considering electric rates in CA, it would be worth considering a suction side cleaner which uses an energy efficient circulation pump. Or, depending on how much you want to use a cleaner, a robot might be a viable replacement for the 280. The robots are very energy efficient and would be very easy on the light bill, and you dont have to interrupt your skimming to use it.
    The Filter - is a 175 sq ft filter. Not considered to be large. Its rated for 120 GPM.
    When it comes to cart filters, bigger is better. A big filter can improve pump efficiency, lengthen time between cartfidge cleanings (nice) and result in longer life of the cartridges. So, if you have the budget to upgrade, do it. Go as big as you can afford. You wont regret it.
    If you dont have the budget to upgrade to a larger filter, then keep in mind the flow rate of whatever new pump you end up with (especially a large VS), so you dont over-do the capacity of the filter. The flow rates on the large VS pumps can be very high when running full speed, which is usually only used when priming the pump. But still, that could result in damage to the cartridge.
    What JasonLion says about the eyeballs is about your only option on the return flow.
    Divin Dave,
    38,521
    Expanding on what Dave said about filters ... for a 20k pool, I would recommend a minimum cartridge filter size of 300 sqft, especially in an area where the pool is "open" year round.
    Oct 2014
    Modesto, CA
    4
    Quote Originally Posted by JasonLion View Post
    Welcome to TFP!
    Thanks! i didnt know about eyeballs
    Oct 2014
    Modesto, CA
    4
    Quote Originally Posted by Divin Dave View Post
    Hi, welcome to TFP!
    The pump -
    I wasnt planning on upgrading the filter, but if i need to, for a better pump, i will
    I was looking at this Pentair system. though the kreepy krawly may have to wait till next year, I'll just vacuum and decide what to do with the booster later. A 60-day warranty on this, kind of scares me though
    with the inlet and outlet being on the same side of this filter, not sure how i would pipe this.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    you can certainly find better pricing that what you linked to.
    You certainly dont need a huge pump such as the 11018 in the link. They are nice pumps though, I have one. That one would certainly require a filter upgrade I belive. Its a 3 HP pump and can really put out some water on high RPM's.
    There are smaller and less expensive VS pumps available that would likely work with your filter. The main thing I suppose, is that one has the features that make you happy.
    I would recommend visting the pentair and hawyard websites and check out the line of VS pumps to get an idea of the features that the different models offer. Then narrow down the list and go from there.
    Divin Dave,
    Oct 2014
    Modesto, CA
    4
    i think with this 1.5hp Pentair pump I dont have to upgrade my filter, and save some cash
    been looking at stuff all day. think im gunna take a break. thanks again
    38,521
    Well, the filter size recommendation is based on the pool size, not the pump size. Although you certainly can have a pump too big for the filter.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    What JBlizzle is right. The Filter should be based on the pool size.
    I just wanted to point out that with that filter, it would not be a good idea to go with a large oversized pump like some people do.
    Divin Dave,
