Results 1 to 11 of 11
Thread: Cracked Filter Please advise
    Sigh, the pressure got too high on my Hayward ec75a filter and burst on the side. Is there anyway of repairing this ? Dropping a grand on a new one doesnt sound like my idea of a plan.
    thanks !
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Cracked Filter Please advise
    I doubt there is a way to repair it that would last. You could probably do some kind of fiberglass patch if you are really handy, but I wouldn't expect it to last too long. I also doubt it was the pressure that caused the failure. Pool components are usually rated higher than the pump pressure could even get to. How old is the filter? If it has been in the sun for a long time it could have gotten brittle from the uv exposure causing it to crack.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Not sure how old it is to be honest. I turned it off since the pressure was at 40 PSI , bumped it and turned it back on.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by stepowell7 View Post
    thanks !
    There is no need to drop a grand on a brand new EC75. And by that I mean, the net has them for $550 with free shippiing or less.If you can do the plumbing yourself then you are set. But if your housing is split there is no feasible cheap/longterm solution, unless it is under warranty.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Agreed, no repIr is going to hold the pressure for long. You will spend time and money just to be frustrated in the end.
    $433 on Amazon including free shipping.
    You may be able to replace just the cracked part. Check out the parts diagram in this PDF.
    Remember, Google is your friend
    Support the site
    22,548
    I don't see your pool or equipment size in your sig, but I'd suggest that since you're likely replacing it anyway take a look and see if it's appropriately sized for your pool. Also don't be tied to a bump filter or even a DE filter just because you have one now.
    thank you ALL. I am going to buy one from Amazon or new from ebay and try and fit myself. Cannot imagine its that difficult.
    Quote Originally Posted by tim5055 View Post
    May 2014
    Franklin, NC
    9,184
    i always take a few photos from different angles to help hook things back up.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Not difficult in the least. Any self respecting pool owner should easily be able to do a little PVC fitting and gluing. thats all it amounts to.
    Divin Dave,
    38,275
    I had a Hayward DE filter split ... I happened to have the pool installed so knew it was less than 5 years old and Hayward sent me a replacement case. Does not sound like you have any way of proving how old it is though.
    Installing a filter ... especially the same one, should be a relatively easy install. Post pictures of the current setup if you want help figuring out the best way to do it.
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I had a DE filter crack. Tried fixing it, no go. Don't even bother trying it won't hold. I was able to replace just the bottom (cracked) half of the filter for a fraction of the cost of a new filter. If you do replace the entire filter, don't limit yourself to keeping the same size or type filter.
    chiefwej
