Thread: Simple Tile and White Plaster Update
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,550
    Hi all,
    I've attached some pics of a simple tile and plaster upgrade I recently had done at a rental house in Bedford, TX (DFW area). Things went pretty smoothly except when it came to the plaster dust. There was just none to speak of. I brushed twice a day for seven days and not once did I see anything which looked to me like "dust". I cleaned the filter while the water was filling up and put in fresh DE as soon as I could turn the pump on. Filter pressure started at 10 lbs. and three weeks later it is maybe 11 lbs. The plaster contractor put in a half gallon of "Startup-TEC". Either something is wrong or this stuff works great!! You can see the bottle in some of the pics.
    [IMG][/IMG]
    [IMG][/IMG]
    Plenty of loose plaster
    [IMG][/IMG]
    [IMG][/IMG]
    New plaster going down
    [IMG][/IMG]
    [IMG][/IMG]
    Nothing but A**holes and elbows for a while
    [IMG][/IMG]
    [IMG][/IMG]
    Water going in.
    [IMG][/IMG]
    Just fit...
    Thanks for looking,
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Simple Tile and White Plaster Update
    They did a really nice job. Looks great ! Sometimes simple is good IMO.
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    I agree 100% with pwrstrk. Often times simple is better.
    Very nice looking pool right there.
    Divin Dave,
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    Looks great. How long did that take? Is that cast concrete coping?
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    Jul 2014
    Bedford, TX
    7,550
    Kpag,
    It took three days. One day to remove the tile, knock off the loose plaster and put on a base coat. One day to install the new tile, and one day to plaster. For the most part they were only there about 4 to 6 hours each day. Not sure how old the pool is, but the coping is the original. It appears to be cast concrete, made for this application. I've seen it on several old pools, so it is not unusual.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    I really like that coping
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
