Thread: Solar cover with vacuum running
    Feb 2015
    San Luis Obispo
    1
    Looking into picking up a solar cover for our pool, but we have a built in vacuum that goes daily. It occurred to me that this might pull the cover around as it moves. Anyone have any experience with this, and if it is a problem, any solutions? Thanks for the help
    Scott
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Is it an inground pool? You could get the little plastic clips that hold a solar cover to a reel and use them to keep it stretched over the pool with bungee cords or something.
    It may still interfere with the vacuum though.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2011
    Long Beach, CA
    2,778
    Re: Solar cover with vacuum running
    Welcome to TFP!
    I've been using my vacuum and solar cover for over 4 years and never experienced a problem. The pool cover fits against the pool walls and the hose just glides under the cover.
