Results 1 to 10 of 10
Thread: dirt and sediment in spa
    Sep 2013
    San Diego, California
    21
    Guys - I've recently noticed my spa getting dirt and sediment sitting on the bottom. I've emptied the spa and vacuumed it but after running the pump the dirt returns. Pool guy came around and said it just needed vacuuming. I'm not sure how these things work but it seems strange to me that the pool is clean and the spa dirty. Can anyone suggest what the problem might be?
    Thanks
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    5) Flow rate of filter; 120
    Location - San Diego, California
    38,272
    Re: dirt and sediment in spa
    Is there water returning to the spa that bypasses the filter? That would be pretty bizarre. The spa usually does not get that goot of circulation in a spill-over mode, so heavier dirt will tend to gather in the spa. You may notice it more because you are not running a cleaner in the spa, like you probably are in the pool.
    You could just occasionally run in spa mode and brush the dirt into the drains.
    Post up pictures of your plumbing if you have questions about how it works.
    wjr75's Avatar
    Jun 2013
    IL
    836
    When I have my pool open for the summer I have my system programed to turn the spa mode on for 15 minutes each day. I also run the spa jets for 5 minutes and the blower for one minute at the beginning of this cycle. This gets fresh chlorine in all the pipes and also stirs everything up and allows the spa main drains to filter all of the water. When my spa isn't in spa mode the water just fills from the bottom of the spa to allow a spill over.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Sep 2013
    21
    Thanks Guys.
    Yes I've drained the spa several times. In the past when I did this that would clear any dirt that goes through the filter right? But the dirt just comes right back. I'll turn on the spa tonight and see if that helps any. I'll ask take a pic of the plumbing and post later
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    Sep 2013
    21
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    Sep 2013
    21
    Hi Guys - anyone have any thoughts on this? My spa is just collecting dirt. I had a filter service about a week ago and I assumed that would have taken care of it but it hasn't and the pool guy doesn't seem able to contribute with a solution. He did return and looked at the spa for a second added some more DE which didn't return to pool or spa so says that "we don't have any holes". He now wants me to pay him to troubleshoot. Anyone have an idea what might be causing dirt in the pool? Thanks
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    38,272
    If you never have any suction coming from the spa and brushing into the drain, then dirt is going to collect there.
    Can't follow the plumbing with just the one picture.
    Sep 2013
    21
    there must be suction coming from the Spa if I can drain it right? Or am I wrong? Also I don't really know what to take a photo of
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    38,272
    Is there a period of time every day when there is suction from the spa? If not, dirt is going to collect.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    do you have raccoons in the area? they are known to "wash up" in pools and/or spas at night. also birds bath in them.
    I have a spa vac that I use when it gets bad. it works pretty good for that. its called catfish. basically an underwater style dustbuster on a stick. under $100.
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
