Results 1 to 9 of 9
Thread: Raypak Gas Heaters
    Raypak Gas Heaters
    Folks I need your guidance.
    I'm going to purchase a natural gas heater for my inground pool. It is an 18X36 with no deep end. It holds about 90,000 liters or 24000 US gallons. It seams that Raypak is the most recommended on the site. I noticed they carry two types a Low Nox and their regular model. Should I go with the regular and if so what size? One more thing, I'm in Canada and would like to extend my season by about 4 weeks (Bring temp up by 10 to 15 degrees farenheight).
    Thanks on advance.
    Randy
    22yr pool owner, 21 yrs Baquacil, installed SWG 2009 - (22000 gal Vinyl In-ground pool)(Pool Pilot DG-220 SWG)(Hayward S244T Sand Filter 3.1 sq ft area 20 gpm)(Hayward SP2607X10 1hp pump)
    38,532
    Re: Raypak Gas Heaters
    We recommend getting the largest heater you can. It will use just about the same amount of gas, but will heat the water faster. You do need to be mindful of what your gas supply and pipes will support though.
    If you are not required to have the Low Nox in your jurisdiction, then I see no reason to pay for it.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Speaking of going big I would also look into hayward's new 500K heater. That will give you an extra boost to get those 4 weeks. Hayward Universal H Series H500FDN
    38,532
    While the 500k is bigger, I do not think I have seen any feedback on it. The Raypak consistently gets very good feedback.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    I would not buy a Hayward given their track record on their FD heaters. The best bet is the Raypak.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Mar 2011
    441
    I though all heaters over 399,000 btu had to have high low gas cutoffs, manual resetting high limits, and a bunch of other ****. I don't think I could "legally" install one here.
    20X40 30,000 gallon gunite pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Quote Originally Posted by ps0303 View Post
    +1 ..
    Factory Warranty Station for:
    Great info. Next set of questions. Copper or Nickel input? Where is the best place to purchase for a good price?
    Copper is fine for a swimming pool. You only need cupro-nickel when you are using ocean water. SWG salt levels do not count as ocean water.
