Thread: SWG Shut Down during winter
    Feb 2015
    Flower Mound, TX
    2
    As a new forum member, I apologize if this has been asked. Since my SWG will not produce chlorine when the temp is in the lower 50s and below, do you suggest turning the SWG off during the winter and simply following your TFP instructions for maintenance of non-SWG pools?
    38,248
    Re: SWG Shut Down during winter
    Welcome to TFP!!
    Yup. Simply supplement the FC with bleach as needed to maintain adequate chlorine in the pool.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi,
    Welcome to TFP!
    Absolutely turn it off. That's exactly how to do it. It might even extend the life of the cell a bit.
    Divin Dave,
    Feb 2015
    Flower Mound, TX
    2
    My SWG stopped generating today because of lack of power. I have determined it is the "black thing" people have discussed in other threads that has deteriorated and I'm ordering a new one. However, until I get it, can I simply shut it off and use the bleach method for chlorine...similar to what I did in the winter time when the water was to cold for the SWG?
    Thanks
    Flower Mound, TX, 14000 gallons, In-Ground, SWG Hayward Aqua-Rite T-15
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yes, just add bleach per poolmath calculations for your pool and cya level.
