Results 1 to 9 of 9
Thread: Wrought Iron pool furniture Q
    Aug 2014
    Taylor, Tx
    53
    The wifey is dead set on getting a pair of wrought iron chaise lounges for the pool deck, but I'm having trouble finding any that don't cost an arm and a leg. $300+ per chair just seems high to me.
    Do any of you seasoned professionals have a recommendation on an inexpensive chair brand or distributor that is good quality?
    Thanks in advance!
    Working on it... 33' x 21' Free form IG gunite with a 56 sf sunledge, 3 bubblers, and raised rear wall with 3' water sheer.
    Pebblesheen, leuder coping, and Oklahoma stone in wall.
    2.5 HP Pentair VS pump, Pentair Quad DE filter, Pentair Racer cleaner
    300 Rainbow Chlorinator, O2 Clear Ozone Sanitizer
    Nov 2013
    Fort Worth, TX
    114
    Re: Wrought Iron pool furniture Q
    All the good patio furniture is very expensive. I don't believe you will find a quality wrought iron chair for less than $300...an likely more. The non-cushion part of the chair will last a lifetime or until you outgrow it.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Wrought iron look really nice...until it starts to rust. its a never ending battle keeping it looking nice around a pool.
    Divin Dave,
    Nov 2013
    Fort Worth, TX
    114
    My wife opted for the aluminum wrought iron look. LOL...They even have it so it looks pre-rusted! To some, rust means character!!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    LOL, I think the aluminum wrouth iron look is perfect for pool!
    I used to think a little rust meant character too, until it started getting bad and I had to fix it! Its starting to get old doing that. I enough other things to do already!
    Quote Originally Posted by Billrector View Post
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Pre-rusted aluminum wrought iron is awesome!
    Aug 2014
    Taylor, Tx
    53
    Thanks for the input, guys. I guess I'll look at the pre-rusted stuff, too!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Divin Dave,
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Beware of rust stains on your deck (ours is Travertine) as we are experiencing.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
