Results 1 to 18 of 18
Thread: Anyway to use waterfall with pump on low speed
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Just a quick question. Currently on low speed my spa does not fill with any water, therefore it seems on low speed my spa is not circulating any pool water into it. I would think I would want the water circulating through both so I don't have issues with the spa. I don't want to run on high-speed all day as the aeration will only add to the pH rising I am trying to keep level (new pool). Thoughts?
    What do you guys recommend?
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Anyway to use waterfall with pump on low speed
    Hello,
    Are you able to adjust the valves to direct more water to the spa? If you have a spill over you can direct most of the flow to the spa, that will spill over to the pool. Can you post a picture of your pool and equipment?
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Interesting. I thought about it...but don't want to screw something up. I can certainly adjust the spa setting when the pump in on high...it's a manual valve (top leftmost valve in the picture below is the one I adjust). I have an iAqualink that I assume shuts down the flow to the spa when the low speed is set. Here's a pic of the valve setup:
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    You are looking for spillover mode (suction from pool and return to spa). Program that feature for the amount of time you want your spa to circulate.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    38,524
    What mode is your pool in for that picture? It looks like every pipe on the suction and return side are open ... which is not usually what you want. In spill-over mode, you would not want any suction from the spa, maybe that is why you do not have a spill-over.
    Can you label the pipes in the picture?
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Quote Originally Posted by bdavis466 View Post
    I do not have a "spillover mode". Just a "clean mode" and "spa mode". The spa mode is what is used when in the spa (pump on, spa suction on, heater on, and spa return on [to get the bubbles], blower, low speed, and pool heat is off).
    No idea what mode it was in for that picture. It was before the startup procedure. I will take one later today with "clean mode" on and "spa mode" on (and it will have the pipes labeled now).
    What brand/model of automation system do you have? They almost all have spillover mode, though it might be called something else and is often more hidden than spa mode.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    iAqualink 2.0 with an RS-8 board. It's weird though...my schedule is "Filter Pump 9a-9p", then low comes on at 5p-9p. With no manual valves changed, I get a waterfall during the day, and nothing at night.
    38,524
    Well, first that is WAY more run time than you need (see Determine Pump Run Time)
    If the valves do not change when low comes on, then you should be getting some water still spilling over. Sounds like adjust the valves to give more flow to the spa is needed. But we need to understand where the valves are positioned in your operating modes.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Perhaps. Since the pool is only two months old and I had a significant scaling issue the first month which required a full drain, acid wash, fill and restart, I haven't had time to determine the appropriate run time yet. I'm also loading CYA via the skimmer, so I want to make sure I get adequate circulation and am under the impression that too much is better than not enough at this point.
    H-12 1/2 Mike's Avatar
    Apr 2014
    Highland Village, TX
    77
    I have an aqualink RS-8 but only run the spillover mode for one hour per day. If "spillover mode" does not show on the indoor panel you must go to the out door control center and make sure the dip switch for Aux 3 is on. It took me 20 years to figure this out because the factory setting for Aux 3 is off.
    16,400 gallon
    Cartridge Filter
    IG
    Intelli-Flo @ 2000rpm
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    According to my iaqualink software the Aux are setup as:
    AUX1 - Air Blower
    AUX2 - Low Speed
    AUX3 - Spa Light
    AUX4 - Pool Light
    AUX5 - Garden Light
    AUX6 - Not assigned
    AUX7 - Not assigned
    Are you talking about another "AUX" input?
    Apr 2014
    77
    What I had was the light on Aux 3 before change but moved the plug-in to Aux -6 and moved the color wheel to Aux 7
    . Then after you set the outside dip switch to "on' you go to your control panel and reassign Aux 6 to pool light.
    16,400 gallon
    Cartridge Filter
    IG
    The Aux 3 switch is not something you can access through software, it is a physical switch on a small block of switches on the automation system circuit board. On that block of switches you want #3 to be on.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Quote Originally Posted by JasonLion View Post
    Totally get it. I'm actually in the technology industry....but one would think the AUX3 of the software would match up with the AUX3 of the hardware....no? (and clearly AUX3 of the software DOES control the spa light)
    Opening the front of the box there is no SPILLWAY button. I will unscrew the panel tomorrow (it's dusk right now and I want to do it with light on).
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Sorry it's taken me so long to get back to this. Work has been kicking my ***. So here are the pictures to the control panel, relays, and dip switches. Also to note, the iAqaulink has two modes "Spa" and "Clean". Neither of them adjust the valves at all when activated. Here is what the control:
    Spa Mode:
    - Filter Pump: On
    - Spa: On
    - Spa Heat: Enabled
    - Everything else: Off
    Clean mode:
    - Filter Pump: On
    Here are the photos:
    http://s143.photobucket.com/user/Th3...r/library/Pool
    As you can see there is something (I haven't traced the wires yet) attached to AUX3.
    I have the owners manual to the Aqualink system, but that only addresses the software interface. Where could I find the manual for the control board (I don't even know what its called if it's not part of the iAqualink line branding).
    Anything make any sense here?
    Mar 2015
    Southern Florida
    23
    From what I'm gathering looking at this and reading the comments upthread, you need to not use the Aux3 relay socket if you want spa spillover, so you need to move whatever if on Aux 3 somewhere else and change S1-3 to get spa spillover mode. Looks like you're using all the relay sockets though, and I have no idea what I'm talking about
    Description of what does what:
    Wires connected to "AUX" headers:
    17k gal, Florida Gem "Double Sky Blue", 11018 Intelliflow VS, Hayward C1750, Autopilot Nano+ SWG, Rheem 6350ti 117kbtu hp, Hayward Colorlogic light (12v)
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Quote Originally Posted by H-12 1/2 Mike View Post
    Just to update everyone on the solution. H-12 1/2 Mike hit the nail on the head. I had the warranty company come out and they moved the Spa light to an available AUX and then left AUX3 open...flipped the dip switch for 3 to "ON" and Spillover mode works flawless now. Thanks again for the help guys!!
