Thread: how to change outlet pipes from intex pool to PVC.
    smitty195's Avatar
    Feb 2015
    Melbourne, Victoria, Australia.
    58
    Hey guys,,,
    I'm having a few dramas trying to change the outlet pipes on my Intex ultra pool.
    What I want to do is change the diameter to a 1 1/2" pvc pipe ,, can it be done ?????
    As most of you guys probably know that the ultra pools come with those crazy 38mm screw on flexible pipes and stupid shut off valves which attach too a plastic T,
    it then has a skinny *** pipe of about 25mm which goes through the side of the pool one runs the internal skimmer and the other just pulls water.
    So,,, if anyone has the know how on this subject please share it with me,,, going nuts trying to work out how its done.
    intex ultra frame round pool 6831g totally hard plumbed with hayward variable speed pump and jandy cs150 cartridge filter... plus a solar heating roof system with a .75 onga pump and 24" sand filter.
    Re: how to change outlet pipes from intex pool to PVC.
    Intex sells adapters that will convert from their proprietary connectors to standard PVC connections. A few people have also built adapters from scratch. Finally, it is also possible to replace all of the non-standard Intex fittings with conventional above ground pool fittings, though that means giving up you Intex pump filter and doing a little careful cutting of the pool to make the holes a little larger.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Hi there Smitty....
    You are going to need to buy the larger intex adapters and cut holes in the pool... I know it sound drastic, but I did it, just like many other intex owners have upgraded.... You can check my thread in my signature to find the pics of how I did it.... The plunger valves will fit perfectly with the new adapters.... But when you buy the larger adapters buy plunger valves at the same time, this will make hose connections much easier....
    Another way around it is using 90 degree pvc elbows to screw directly onto the new intex fittings, and putting in ball valves so you can cut the water off.... I hope this helps... You can also search for Intex Adapters in the search function....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    I am glad to see that Laceygirl found this post. I was going to Point her at your intro. post. Listen to her and she can help you out.
    Kim
