Thread: throw away old Super Blue?
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    Have 3 bottles of Super Blue left over from times past. Don't need it. Time to get rid of it.
    Could take to ?garbage ?hazardous waste but
    Is there anything wrong with just using it up?
    Does it do anything bad? Like gum up the glass?
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: throw away old Super Blue?
    Sell it to someone who hasn't seen the light yet. They'll think they got a good deal.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mar 2007
    San Rafael, CA USA
    12,082
    Robarb™ Super Blue is a clarifier so you wouldn't want to use it up. Overdosing can cause cloudy water and gum up the filter. You should not need to use it. It likely is similar to GLB® Clear Blue® made by the same company (Advantis Technologies bought by Laporte Water Technologies bought by Arch Chemical bought by Lonza) which is a product I used once to quickly clear a pool after a phosphate remover experiment clouded the water and my wife would be swimming the next morning so I needed faster-than-usual clearing. So while it probably works in some situations, you'll likely not have any need to use it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    We can't advise you on proper disposal of any product, but perhaps the mfr can. I would think if it's safe to swim in, it can't be too harmful.
    Essential Links:
