Thread: Titration or Comparator Test for Baqua Spa Oxidizer
    Feb 2015
    Bentonville, VA
    1
    I'm considering shifting to the Baqua Spa system. Instead of the 4-way test strips, is there a reliable titration or comparator test that can be used to determine the Sanitizer levels?
    Re: Titration or Comparator Test for Baqua Spa Oxidizer
    Welcome to TFP!
    There is a test kit that measures both Sanitizer and Oxidizer, Taylor K-1725. It seems to be fairly expensive however.
    Mar 2007
    San Rafael, CA USA
    12,082
    What system are you shifting from? Chlorine, bromine, something else? Why are you shifting? Baqua is an expensive system and usually only used by those rare individuals who have a chemical sensitivity to both chlorine and bromine. Another alternative that minimizes chlorine or bromine use is Nature2 with MPS.
