Leak in Jandy Plus HP pump housing
With the pump off, you can try tightening the union nut. If that doesn't work, turn the pump back off and unscrew the union nut to see if you can see a crack.
Based on the spray pattern, I'm thinking that the pump housing might be cracked.
That type of plastic does not hold adhesives well. Also, a crack in a pressurized vessel creates a weakness that could allow a complete failure. I would recommend replacement.
Yes, I did the repair but I'm thinking I may need to buy a replacement housing. The problem is, I unscrewed the 6 or so screws on the back, you can see two of the screws in the picture above and no way will the motor separate from the body. Does anyone know how to get it to separate?
To get it to separate, you have to remove the impeller and then the four screws the hold the motor to the seal plate (backplate).
However, based on the age of the pump, it might be better to get a whole new pump that would be more efficient.
well I was planning to get the Ecotech EZ variable speed motor to go with it. Even with the housing, motor, and automation control box for that motor, it is still like 300 less than a new pump.
so I unscrewed the 6 screws on the back of the pump, and you say I need to take the 4 screws out holding the motor in. I'm not sure what you mean by removing the impeller, I'm assuming I can't remove it unless I have the pump separated.
Ok, after you remove the six screws from the pump's seal plate you will need to pull the motor AND the drivetrain. It will look like this: http://wetheadmedia.com/wp-content/...gging-Impeller-On-The-Hayward-Super-Pump-.jpg
The the cone at the end of the motor will be the diffuser, remove the two connecting screws: http://www.mypoolyard.com/images/products/jandy_php_wftr_mhpm_jep_shp_pump_diffuser_r0445400.jpg
Then you must remove the impeller which is a little complicated but can be see here: https://www.youtube.com/watch?v=C41Rp4bkNK4
Yes, I get that, but when I take the 6 screws out, the whole assemble is pulling back maybe 1/4 inch and no further.
Make sure that you're not removing the motor mounting screws yet. Sometimes, the bond wire or electrical conduit are stretched tight to reach the motor and make it difficult to remove the motor.
