Results 1 to 17 of 17
Thread: Leak in Jandy Plus HP pump housing
    Oct 2007
    Parkland, FL
    752
    I noticed my pump leaking today, picture attached. Is this something I can fix? If so how can I fix it? I'd like to take care of it as soon as possible.
    Thanks
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Jan 2013
    Friendswood, TX
    320
    Re: Leak in Jandy Plus HP pump housing
    Kinda hard to tell from the angle of the picture but looks like the coupling. Can you determine if it is the coupling of the body?
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    With the pump off, you can try tightening the union nut. If that doesn't work, turn the pump back off and unscrew the union nut to see if you can see a crack.
    Based on the spray pattern, I'm thinking that the pump housing might be cracked.
    Support the site
    Oct 2007
    Parkland, FL
    752
    Its definately the housing. What can I use to repair it if anything?
    There's no good way to fix it. Is it under warranty?
    Even if it's not under warranty, Jandy might replace it for you if you ask.
    Support the site
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by JamesW View Post
    Its at least 8 years old. I bought some JB Weld clear weld. I figure I can put some in the inside and the outside and see if that fixes it.
    Oct 2007
    Parkland, FL
    752
    I put the jb weld on the inside and outside of the leak area, there is a seem there where I believe it was leaking, that should hold it I think?
    That type of plastic does not hold adhesives well. Also, a crack in a pressurized vessel creates a weakness that could allow a complete failure. I would recommend replacement.
    Support the site
    Oct 2007
    Parkland, FL
    752
    Yes, I did the repair but I'm thinking I may need to buy a replacement housing. The problem is, I unscrewed the 6 or so screws on the back, you can see two of the screws in the picture above and no way will the motor separate from the body. Does anyone know how to get it to separate?
    To get it to separate, you have to remove the impeller and then the four screws the hold the motor to the seal plate (backplate).
    However, based on the age of the pump, it might be better to get a whole new pump that would be more efficient.
    Support the site
    Oct 2007
    Parkland, FL
    752
    well I was planning to get the Ecotech EZ variable speed motor to go with it. Even with the housing, motor, and automation control box for that motor, it is still like 300 less than a new pump.
    so I unscrewed the 6 screws on the back of the pump, and you say I need to take the 4 screws out holding the motor in. I'm not sure what you mean by removing the impeller, I'm assuming I can't remove it unless I have the pump separated.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Ok, after you remove the six screws from the pump's seal plate you will need to pull the motor AND the drivetrain. It will look like this: http://wetheadmedia.com/wp-content/u...uper-Pump-.jpg
    The the cone at the end of the motor will be the diffuser, remove the two connecting screws: http://www.mypoolyard.com/images/pro...r_r0445400.jpg
    Then you must remove the impeller which is a little complicated but can be see here: https://www.youtube.com/watch?v=C41Rp4bkNK4
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by Citizen View Post
    Yes, I get that, but when I take the 6 screws out, the whole assemble is pulling back maybe 1/4 inch and no further.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by robl45 View Post
    It may be stuck on something or the grime may have the seal a little stubborn. Looking at the parts diagram of the pump there is nothing keeping it in place.
    There are 8 screws, not just 6. There are two at the bottom that need to come out.
    Support the site
    Oct 2007
    Parkland, FL
    752
    Yea, I got them all, my mistake saying 6 screws., I'll have to pull a little harder when I try to take it out I guess. I didn't want to break anything. My hayward pump at the last house just pulled right apart.
    Make sure that you're not removing the motor mounting screws yet. Sometimes, the bond wire or electrical conduit are stretched tight to reach the motor and make it difficult to remove the motor.
    Support the site
