Thread: Connecting two pools. Plumming
    Feb 2015
    Curacao
    4
    Question Connecting two pools. Plumming
    Hi
    We already have a concrete in ground pool of 14 x 5 meters and 1.4m deep Not so big.
    Now we build a concrete whirlpool next to it.
    Round diameter 3.5 meters.
    simce the main pool is not very large nor is the whirlpool, can I connect the whirlpool to the existi g pump and filtration system?
    If so, here is my question.
    The contractor build the whirlpool about 10 higher (waterlevel) then the main pool.
    Will the water in the whirlpool be too low?
    The contractor talks about a return valve that will prevent the water from flowing back.
    I have doubts.
    Anyone with experience?
    Thanks
    Hans
    Re: Connecting two pools. Plumming
    Welcome to TFP!
    Yes, it is certainly possible to have the pool and whirlpool share plumbing. Setups like the one you describe are very common, including the difference in water surface heights.
    Your contractor is correct, a check valve on the whirlpool return line will prevent the whirlpool from draining down. You will also want someway for the spa to overflow into the pool. This can either be a visible waterfall or be hidden in the plumbing.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Welcome to the forum!
    It's called a check valve, and it allows water to flow in only direction. They are very common. My spa is 18" higher than my pool, and the only time it drains is when there is some debris caught in the check valve. It takes about 2 minutes to disassemble and clean and put back together.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    mas985's Avatar
    Pleasanton, CA
    11,741
    Here is a typical setup for a pool/spa sharing equipment:
    Mark
    Feb 2015
    Curacao
    4
    Quote Originally Posted by mas985 View Post
    Hi Mark,
    Thanks a kot, that makes things clear.
    Hans
    Note: in the diagram posted above, the "Spa Make-up" line is optional and in practice most builders don't install it. When you remove the spa make-up line, you move the check valve over to the spa return line. Using a spa make-up line typically requires higher flow rates and is less energy efficient, though it can be a good idea if you don't have an automation system. With an automation system you would instead use spillover mode (return goes to the spa, suction comes from the pool) about one hour a day. Without automation a make-up line is simpler as you don't need to be changing the valves manually every day.
