Thread: Pentair Intellitouch - Problems with Indoor Controller
    Feb 2015
    Agoura hills, CA
    2
    I have a Pentair Intellitouch and the Indoor controller is unresponsive. Has anyone else experienced this?
    I started a new thread for your post as it was originally posted to an old thread. Since posts to older threads are less likely to get answered, moving it to a new thread will increase the likelihood of getting responses. Also reworded the original post to provide a little more context. Feel free to add any additional details.
    - BoDarville, TFP Moderator
    Text of original post: I am having this same issue - did you ever figure out the problem? Thanks!
    ps0303's Avatar
    Jul 2011
    FL
    3,679
    Re: Pentair Intellitouch - Problems with Indoor Controller
    Have you tried resetting it?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Feb 2015
    Agoura hills, CA
    2
    How does one reset the system? I've hit the reset button on the main panel... the 1 and 7 buttons flash alternately but that is about it. Can you walk me through it? I have only one panel (no expansion load centers). thanks
    The most common problem is the wire running to the indoor panel getting disconnected or cut. Check the connections at both ends, and to the extent possible trace along the wire run and see if there are any cuts or deep nicks.
