Results 1 to 11 of 11
Thread: Pump Issue/Identification
    Jan 2015
    Portland, Oregon
    4
    My pool's pump seems to be leaking from the suction side (air bubbles in pool return), I have noticed that when the pump turns off water will actually burst out of the top of the pump basket area.
    When I remove the lid, the Oring is very sticky (like some type of adhesive was put on it).
    -Is it normal for the oring to be sticky? If I replace the o ring should I also put the same adhesive on it, or should I completely clean the adhesive from the joint?
    I would have replaced the o ring and figured this out by now but I have no idea what size o ring I need because I have no idea what pump it is. I have attached pictures of the pump and a technical sticker, If anyone can ID it for me I would greatly appreciate it (and then i can finally determine which o ring i need!)
    Thanks in advance!!
    -Fisher
    38,489
    Re: Pump Issue/Identification
    Welcome to TFP!!!
    The o ring should not really be sticky. The use of the wrong type of lube could have made it that way. I suggest you get a new oring and use silicone lube on it.
    BTW, no picture showed up for me, could be a firewall issue: How To Post Pictures
    Jan 2015
    Portland, Oregon
    4
    Thanks a bunch! This site has helped me make heads and tails of my pool.
    Yeah I noticed that too, I was in the process of fixing that but I now longer see my original post.
    Anyway, here are the two pictures I have.
    It's a Sta-Rite Max-E-Glass or Dura-Glass. The lid O-ring is part number U9-229.
    Edit: It might be a Max-E-Glas II or a Dura-Glas II. THE O-ring would be a U9-375.
    Support the site
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    You would want to get a silicone based lube that is available from most big box stores and or hardware stores. Clean up all the "sticky" you can and lightly lube the new O ring on installation.
    Solar Blanket, Well Water, Borax Added. 76
    Jan 2015
    Portland, Oregon
    4
    Quote Originally Posted by JamesW View Post
    It is a 7" o ring, so the u9-375 might be it. Is there any other option it might likely be? (I want to be 100% sure before I order it online)
    Thank you so much!
    Quote Originally Posted by kiss4afrog View Post
    I was planning on using a silicon based o ring lube I use on my paintball o rings (it has the consistency of oil). Is it better to get a silicon lube with a thicker consistency?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    I'm not sure it would make a difference between a grease or oil as long as they are both silicone based and not petroleum. As long as it's clean and allows the O ring to move a little to allow it to seal that's all that matters.
    There's a pump id plate on the flat part right behind the big clamp. It's silver metal. It's hard to find unless you know it's there. You might need to clean it a bit to read it.
    You can see the aluminum id plate in the picture. It's about 1" x 3". The pump model number is stamped into it from the back. The numbers are raised. If you can't read it, you might be able to put a piece of paper over the plate and lightly rub a pencil over it to see if the number will transfer through the paper.
    If necessary, you could get both O-rings to see which fits.
    Support the site
    Jan 2015
    Portland, Oregon
    4
    The pump model is p4ea6f-187L, so the correct o ring is the U9-375, correct?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Yes, the U9-375 is the correct O Ring
    item 17 on the exploded view.
    http://www.poolpartsonline.com/p-845...ump-parts.aspx
    Divin Dave,
    You have a Max-E-Glas II.
    Support the site
