Thread: Repair Polaris booster pump connection
    Jun 2007
    North Florida
    79
    We've got a bad connection where our Polaris booster pump flexible hose meets the PVC return line. When I turn on the Polaris, we first got drips but are now getting a fine misty spray.
    The hose has been disconnected and we've tried to reconnect it according to the initial installation instructions. Pulling and twisting the sleeve of the quick connect over the hose has been a bit of a problem, as there's another PVC line that runs above this connection, making it difficut for one to pull up very far. Still, I thought we had a good connection, but it only lasted an hour or so and then was leaking again.
    Any tricks of the trade we could use to get this reconnected and our cleaner operational again??? Do we need a new sleeve? New hose? Thanks.
    BTW, our set-up is 2 years old (3rd summer), out in the elements, and gets a lot of use year-round, as we don't close the pool.
    Sandy
    15,600 gallon, screened 15 x 30 sport pool with 6 x 8 baja shelf, IG plaster (Diamondbrite??), Hayward cartridge filter, 1-HP Hayward pump, Hayward/EUS Mark VI heat pump, Polaris 280, AquaRite SWCG
    Dec 2007
    Central New York
    504
    Re: Repair Polaris booster pump connection
    Are you talking about pushing a 3/4 or 1 inch hose onto a barb fitting?
    If that's what your trying to do, I would coat the barb fitting with alittle teflon pipe dope; then push the hose on. Then tighten the band clamps.
    On second thought, maybe that's not what your talking about.
    Atleast this post will bump the thread up.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Jun 2007
    North Florida
    79
    Hotrod30...yes, I'm trying to push a hose onto a barb fitting (I think that's what it's called?). But instead of a wire clamp, there's a plastic, circular sleeve that you pull up and over the hose that holds everything securely - at least that's the theory.
    At first, we thought the sleeve might be damaged, but it looks OK and the plastic pieces inside the sleeve look to be all there and intact.
    The Teflon dope might help...I'm also wondering if the hose maybe needs to be cut so that there's "new" hose getting put onto the barb and getting clamped down by the sleeve. Perhaps the part of the hose that has been clamped for all this time is no longer allowing a watertight seal? Just some thoughts I've had...
    Thanks for the reply and bump.
    Sandy
    Dec 2007
    Central New York
    504
    It might be worth it to cut some of the old hose off; maybe 1/2 inch more than it was on the barb. It would be worth it to have a couple of band clamps for the size hose you are working with near by. You can buy band clamps at Lowes or HD.
    Hotrod30
    Pentair VF3050 pump
    Jun 2007
    North Florida
    79
    Thanks Hotrod30...guess a trip to HD is on my agenda for tomorrow. Gotta get this cleaner going again!
    Sandy
