Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Air in filter
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Air in filter
    How much air should be in the filter?
    When I open the pressure valve (with pump off) it always has air to release. Is this normal or should it be minimal? I assume it has some air creating pressure but how much is normal?
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Air in filter
    Shouldn't be any. What does your strainer basket look like?
    38,305
    Re: Air in filter
    If the pump is off, then there is no pressure in the filter or anywhere else in the system. The air you are hearing is being sucked in due to the water then being allowed to drain out of the filter.
    To check for air in the filter, the pump should be running and you should open the air release valve to see if any air comes out or if only water shoots out.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Air in filter
    What he said - need the pump running. Otherwise you're just hearing the air going into the filter as the weight of the water pulls it back into the pool.
    Solar Blanket, Well Water, Borax Added. 68
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Air in filter
    Ok.
    Sometimes there is some air when the pump is running too. Could this be air I allowed into the system by opening the filter gauge when pump is not running?
    First time pool owner trying to maintain myself. Just concerned.
    There are a few bubbles in pump strainer. Had a pentair service guy out once for something else and he thought there may be a hairline crack in pump basket lid. He said he ordered a new one but hasn't been back yet. It was a couple weeks ago.
    I also sometimes see some small bubbles out of return. I have a salt water chlorinator and acid dispenser if that helps.
    Thanks
    38,305
    Re: Air in filter
    A SWG can also have air bubbles show up in the pool ... mine certainly does.
    Just open the filter air valve after the pump has been on for awhile and see if any air comes out ... while the pump is running.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Air in filter
    Sometimes yes sometimes no.
    I'll leave it alone for s couple days and check it again while running and see.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Air in filter
    I checked again with pump running. No air.
    Thanks for the input.
    Re: Air in filter
    Feb 2015
    Southern California
    2
    Re: Air in filter
    Sometimes, air bubbles returning to the pool can be caused by debris clogging the pump impeller.
    With the pump OFF remove the lid and basket and feel for debris in the impeller with your fingers.
    You can also open the air valve on the filter and see if the the back flow of water dislodges anything from the impeller.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Air in filter
    thanks.
    the bubbles don't always come out of returns just sometimes. I would think they would be constant in a situation such as you describe.
    38,305
    Re: Air in filter
    Have you seen that the bubbles are only occurring when the SWG is generating?
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Air in filter
    How can I tell? By turning it off?
    I assume it's constanyly generating when it's getting flow.
    Jun 2011
    Long Beach, CA
    2,790
    Re: Air in filter
    I only see bubbles in the return when the SWG is making chlorine and the pump is on low speed. When the pump is on high speed I will not get bubbles from the SWG.
    Right now I believe your SWG % is 25%, from another thread, so it is only making chlorine 25% of the time that the pump is running.
    It sounds like your system is in good shape.
    38,305
    Re: Air in filter
    That is not how SWG work. The % setting is the amount of time in some given period (usually 1-2 hours I think) that the SWG is generating. You can override it by setting the % to 100% and it will always be generating or set it to 0% and it will never be generating. Or I would there is some indicator on it to let you know when it is actually generating.
    But, since you have never filled out your signature, I have no idea what equipment you have.
    Please add your pool details to your signature as described HERE as it will help us help you.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Air in filter
    Details are in my signature. I think that when I post from my iPhone they don't show up for some reason.
    I do see them in a post above.
    Full penair automation including ic40 and intelliph.
    38,305
    Re: Air in filter
    Ah you are right. When on your phone, how do you access the forum?
    My signature always shows up when I use my phone with an old version of Tapatalk
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Air in filter
    Quote Originally Posted by dumbcluck View Post
    I can see your sig using Tapatalk.
    Jeff
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Air in filter
    I don't use tapatalk
  20. Back To Top    #20
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Air in filter
    Is it odd that my filter reads differently from day to day?
    Some days it's at 3 others 6 or 5. Not necessarily heading in one direction but varying from day to day. Always within 3 psi from each other. Shouldn't it be a constant?
    Is this indicative of a problem or does it seem ok?
