Results 1 to 20 of 20
Thread: Best sand filter for $ - 16' Intex ultra
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    Looking to upgrade my pump/filter as I'm sick of rinsing/replacing cartridges for my 16' ultra intex.
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    38,521
    Re: Best sand filter for $ - 16' Intex ultra
    Are you looking for a filter and a pump? What pump are you currently running?
    Jun 2014
    206
    Currently running the 685 I think the 1200 or 1500 gph Krystal. Is the saltwater worth it or rust out pool?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's only my opinion but I don't think going Salt isn't worth it in that size of pool. It's so easy and cheap to add the tiny amount of Bleach it will take.
    Here is a good buy on a sand filter. Hard to beat for the money I think.
    http://www.amazon.com/gp/aw/d/B004VU...5iL&ref=plSrch
    Essential Links:
    Jun 2014
    206
    I used bleach last year without issue, which is why I wouldn't mind just a sand upgrade
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Hi there,
    I'm a cartridge filter fan.... BUT I upgraded to a 100 sq ft cartridge filter, I only have to clean it once a season....
    Its about 1 metre tall, and about 35 centimetres wide... Very big, but does a great job....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2014
    206
    Any feedback on intex sand filters, preferably 3000 gph model? Amazon has great feedback
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    38,521
    The Intex sand filters are a vast upgrade from the tiny little Intex cartridges.
    With your size pool, there is not likely a compelling reason to start looking at separate 2-speed pumps and larger sand filters for major pool brands unless you were intending to upgrade the pool itself in the near term.
    Jun 2014
    206
    I'll prob roll with intex 3000, prob a in ground in a few years haha
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Apr 2014
    FOUR cORNERS
    111
    I have the blue /grey 2 piece sand filter, 14 inch if i'm not mistaken 16'x48" metal frame and it has been running now for 4 years, this season will be five, water clear as ever, turn over a couple hours, hard plumbed with help of this sight, installed a Hayward skimmer, just take care of all of it and you two can have many years of pleasure!!!!!
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Jun 2014
    206
    Thank you, I have the Hayward skimmer as well
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Orlando, FL
    690
    I have this Intex sand filter and I am using it with a Hayward 3/4 hp pump all attached to a Sharkline 15x52in pool. I have had this filter (according to Amazon, since June 19, 2013) and it has not caused any problems until recently when the rubber gasket that is inside started to come out when I would rotate the handle. I pushed it back in and it has been fine. I think it got a little dry because I do not have to backwash very much so the handle does not get rotated as often as it needs to. The filter does exactly what it should and I am happy with it. The Intex pumps are another story. They seem to tear up pretty quickly.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jun 2014
    206
    Final bump before I pull the trigger this week! Looking at this one http://www.amazon.com/gp/aw/d/B00GSP...ob_neva_mobile
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by Slammed01 View Post
    That is the one I would get for your pool. I have the 2800 gph
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    jmcdtucson's Avatar
    Jun 2014
    317
    I have that one and love it. Just get it.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Jun 2014
    206
    Ordered last night!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    How much sand is recommended for the 3000?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Mine took about 50-70 lbs of #20 silica sand. So if you get 2 50 pound bags that should be enough.
    Lisa
  20. Back To Top    #20
    Jun 2014
    206
    Got 2 50s, about 3" low. Shucks!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
