Thread: New pebble sheen discoloration
    Houston, TX
    1,102
    Our pebble sheen was installed 3 wks ago this Monday, acid washed Tues, then filled & balanced per Man Spec.
    Last night when I turned on the house flood lights, I could see some darker areas on the pool walls, bottom some and a bench 20" deep. The water is:
    PH 7.8
    TA 180
    CL 1.5
    Is the color variation normal or is something going on here?
    Thank you very much
    Tstex
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New pebble sheen discoloration
    Hard to say without seeing it, but any colored finish will have some variation.
    Essential Links:
