Results 1 to 11 of 11
Thread: Reducing CH via lime softening process
    Northrider23's Avatar
    Sep 2013
    South Florida
    175
    Wondering if anybody ever attempted it as decried in this thread:
    http://www.poolforum.com/pf2/showthr...atment-Process
    I did the test on the bucket as explained there and the CH went from 450 down to 25.
    I did a Search on this forum but didn't get much. I got everything to get it don't but still a bit hesitant. Advice please.
    Re: Reducing CH via lime softening process
    That can work, though if you try it be certain to follow all of the steps and don't proceed unless you meet all of the criteria. We don't recommend it because it doesn't meet our "trouble free" criteria. It certainly won't work for everyone, can cause metal staining, and failing to follow the directions correctly can create quite a mess. But if you are methodical, follow the instructions carefully, and meet the criteria, it can work out very nicely.
    Sep 2013
    South Florida
    175
    Thanks for the quick response.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Its a risky proposition. I've been directly involved with this in the Industrial water treatment industry for a long time, and I'm not sure I would attempt it in my pool. A bucket is one thing, but it will go differently in the pool. Circulation and contact/residence time is a big concern. Then, if it works well, how easy will it be to filter out? Much easier in theory and on paper....and more than a little scary to me. It's the unknown that would deter me. You'll need to be very, very careful and critical on the alkalinity control. Extremely accurate dosing is also crucial to it being successful.
    If you do it, please report back and let us know how it works out. It would be very interesting to see the results.
    Essential Links:
    Sep 2013
    South Florida
    175
    Couldn't find enough info about it at the other forum either. So I'll probably hold off. It's just frustrating because my calcium levels are high (450) and our fill water it's not much better. Getting scale buildup even dosing the pool every other day to keep ph 7.2-7.4.
    Thanks again for the input
    CH at 450 is really not all that high. CH is typically manageable up to a little over 1,000 (with a fair bit of effort). You should be able to compensate for CH around 450 and prevent scaling by keeping your TA just a little lower than normal. If you post a full set of test results we can give you more specific advice.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Just wanted to second Jason. 450 is very manageable, and many of us wish we had that little. The most important thing you can do is watch and maintain your pH very carefully.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Well now this is interesting. I had no idea.
    To be honest, it sorta surprises me that some of the really experienced TFPers out West haven't given this a go.
    Divin Dave,
    Sep 2013
    South Florida
    175
    Sure things guys
    FC. 4
    CC. 0
    PH. 7.2 - 7.4
    TA. 60
    CYA. 60
    CH. 450
    I'm still manually dosing the chlorine because PH still goes up regularly and I know SWG makes PH rise more quickly. As soon as ph stabilizes a bit ill make the switch. Pool is 8 months old. The issue is I'm getting a lot of calcium buildup.
    With TA around 60 you shouldn't be seeing any scaling unless you let the PH go completely (i.e. over 8.2), though there is some chance of scaling inside the SWG at a PH above 7.8.
    One thing you can do to further lower the odds of calcium scaling would be to add borates and then lower the TA further. Doing that should allow you to stabilize the PH below 8.0 and hopefully stop needing to add acid.
    Sep 2013
    South Florida
    175
    thanks Jason. Borates should be going in this week. According to pool calculator i need 23boxes of borax for 29500 gal pool. I need to pick up another 9 boxes and it's going in.
