Results 1 to 7 of 7
Thread: Please help me with pump selection!!
    Hi all!! Looking for help selecting a variable speed replacement for my 2hp superpump. My pool is about 38000 gallons with 2 skimmers a main drain, and a water slide with water feed going to it. Pump is currently controlled by a intermatic analog timer. Also I will be adding a stenner pump this year for liquid chlorine dispensing. Currently I have an older hayward propane heater that is pilot lit and will be replacing this year also. So I don't mind recommendations on automation for above!
    Thanks!!
    Re: Please help me with pump selection!!
    What is your cost for electricity?
    Also, do you have a spa, waterfall, or other water features?
    I think electric is about .17 per kWh but I'd have to look. Only water feature is the water slide, no waterfall or spa.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    You may wan to look at a 2-speed motor with and a new shaft seal. The price difference between the VSM and a two speed motor make the two speed motor more economical.
    Quote Originally Posted by bobodaclown View Post
    Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk
    I was thinking about doing the two speed but since i have to re plumb for the new heater I'd just rather do the vs pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I love my Pentair 3hp VS pump. More pump than I need and infinite control. And very economical to run at lower rpm.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    These rates are close to the point ($0.20 per kWh) where we would recommend a VS pump over a 2-speed. Before making a decision, here are some factors I would suggest considering:
    1. What's the recent trend in your electric rates? If they have been rising, you may want to consider a VS pump. If they are staying relatively constant, a 2-speed would likely be a more cost-effective option.
    2. Price difference between VS and 2-speed. VS pumps are becoming more common and there are more models to choose from at various price points compared to a couple of years ago. But 2-speed pumps have also come down in price compared to when they were introduced. Probably worth your time to do a little payback analysis.
    3. Reliability: VS pumps have a lot of electronic controls and these are subject to malfunctions and electrical surges, especially in areas that experience frequent thunderstorms. You can mitigate this risk with a surge suppressor, but this needs to be factored into the cost analysis. OTOH, 2-speed pumps are much simpler and do not have all the electronics of the VS pumps. Simpler design = increased reliability, all other factors constant.
    4. Degree of control & flexibility needed: The VS pumps win on this point, but this would be a major factor for pools with several water features.
