Results 1 to 7 of 7
Thread: Flushed suction side, now pool's cloudy
    Jan 2015
    TX
    49
    The pump was not sucking any water from pool, so I stopped pump, shoved a hose in the suction side hole inside pump, made a good seal, and flushed the "tubes" one by one(adjusting valves so only one was open).... At the end I checked each valve that it was pulling in water to the pump,, except the main drain didn't...when I went back to the pool I saw a circle of mud around the main drain
    now the suction side is working properly and I vacuumed all that dirt but now the pool is a little hazy
    What should I do let the filter run overnight?
    Oct 2014
    Sacramento, CA
    72
    Re: Flushed suction side, now pool's cloudy
    Whats your chemical readings?
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Jan 2015
    TX
    49
    hm. i didnt check...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Sounds like you've been brushing silt into the drain expecting it to be sucked away to the filter. Is there a separate valve for the main drain, or does it go through a two-hole skimmer? You might need to keep flushing.
    Jan 2015
    TX
    49
    this is an established pool that came with the house i just got, ... the main drain has its own valve, and it looks like they had the MD valve turned off - i guess because the MD was clogged ...
    Jan 2015
    TX
    49
    ok went by pool today and it looks back to normal, nice and clear (probably dust settled on bottom)
    ... what do i do with that clogged main drain now? i dont want to flush it back into the pool...
    Richard320's Avatar
    Jan 2010
    19,065
    Quote Originally Posted by zacc44 View Post
    Lots of people don't have a main drain. You can point one of the return eyeballs down at the deep end to improve circulation and forget it. Or bite the bullet and blow it clear and deal with the mess using the vacuum.
