Results 1 to 7 of 7
Thread: Light yellowish staining after SLAM/Fiberglass
    tam87's Avatar
    Feb 2015
    New Port Richey, FL
    28
    Hi All, Just completed SLAM last week, levels looking good, I added a bit more bleach a few days ago per advice on my other post to help raise chlorine since I have SWG, but today developing a light yellowish/brownish stain on smooth areas--doesn't seem to readily come off? Any ideas??
    Water is crystal clear and these stains definitely were NOT present before today!
    FC-6
    CC 0
    PH 7.6
    TA 90
    CH 190
    CYA hovering around 90
    Thoughts?
    Am going to buy some refills from TFT --do I need to get some other test beyond whats in my Taylor kit for this issue?
    Brand new (9/2014) Fiberglass 7500 gallon with 6 person spa spillover, Aquarite SWG/ Turbo Cell rated to 15,000 gallons, Hayward pump and cartridge filter. Electric Hayward heater for spa only.
    38,290
    Re: Light yellowish staining after SLAM/Fiberglass
    The only thought would be metal staining, but that would have been more likely to happen during the SLAM at high FC levels than after you let the FC drop back down.
    You should not need any additional tests that those in the kits we recommend. FYI, it is highly likely that tftestkits.net will have a sale on refills in about a month (not sure how desperate you are).
    tam87's Avatar
    Feb 2015
    New Port Richey, FL
    28
    So how do I get rid of them? Thanks for the tip BTW on upcoming sale!
    38,290
    Well, first you need to ID the stain. Try putting a vitamin C tablet on the stain, if it lightens in a couple minutes, that would confirm iron staining.
    tam87's Avatar
    Feb 2015
    New Port Richey, FL
    28
    Ahh yes--did the Vit c tablet test and it came right off! Saw the article posted that describes the Ascorbic acid treatment, but I don't want to take my chlorine back down now that I have everything cleaned up! Grrr. Do these stains cause any long term harm if I wait to remove? Do they ever go away on own?
    Or I could scrub my whole pool with Vitamin c tablets ! LOL!
    No, no long term harm. The only impact is visual.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Tam87, see my post on metal stains. My fill water doesn't have metals and I'm thinking folks that owned pool before me must have put some kind of Algaecide containing metals in the pool. I've done the AA treatment a few times and use a Metal Klear on a weekly basis to keep it at bay as well as tad lower ph. Good luck w that!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
