Thread: Looking for LED light replacement suggestions and help
    May 2011
    Miami, FL
    271
    My existing 12v light has a water line about 1/3 of the way. After some reading, I learned that I can easily remove the light assembly and replace the gasket. I am willing to do it, but figured it's the time to replace my boring light from 2004 with a cool LED light.
    1) Do I have to worry about compatibility with my existing brand of nich/housing?
    2) Is there a brand that sticks out in quality? I see a lot of J&J lights mentioned, but I wonder if there are other brands.
    Thanks
    16,900 gallon inground pool (16x30 with spa bench)
    Sta-rite cartridge filter
    Diamondbrite surface, redone in 2017.
    1.5hp Hayward Super Pump
    Hayward Navigator Pro suction cleaner with V-flex kit
    38,301
    Re: Looking for LED light replacement suggestions and help
    I got the 120V J&J, works well. I have not seen other brands with multi-color LED replacement bulbs.
    Assuming the bulbs are similar sizes with the same connector, there should not be compatibility issues.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello,
    Be sure that the LED will fit the housing. Or be able to return the bulb. It would stink to spend that money on the bulb and not be able to use it.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by nabril15 View Post
    Thanks
    The J&J bulbs I think are only compatible with the Pentair Amerilite, Hayward Astrolite, and Jacuzzi Full Moon; so make sure yours is one of those. J&J would be my suggestion of manufacturer
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have a J&J, it works well. Be advised though, that the intensity of the LED light will not match how intesive the regular one is. I would say in the neighborhood of 30% less intensity.
    Divin Dave,
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I opted for the BulbWizards PoolBright 202 LED Color Changing Replacement Bulb (see my review here).
    At the time it was about half the price of the competitor's bulb, so I figured it was worth a try. I haven't seen anyone else here with this bulb, but I love mine.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
